Author Topic: air con problems need help!  (Read 1222 times)
Offline Andy1994
« on: November 02, 2013, 08:34:57 pm »
Scanned car with vagcom no codes!, scanned car with launcg diagnostic and had a code for "refrigerant pressure low". Checked the system which was full and no leaks so replaced the pressure sensor rechecked and no codes however i still dont get cold air and the fans dont come on but, when i press the econ button to either turn on or off the revs do fluctuate at idle as if its working so can shed some light on what my problem is
Offline doylebros
  • -Receive: 310
Re: air con problems need help!
« Reply #1 on: November 02, 2013, 08:38:01 pm »
Use VCDS to run an output test, then use measuring blocks to run the fans & check compressor current see what you find.
Offline Andy1994
« Reply #2 on: November 02, 2013, 08:40:25 pm »
is this easy enough to do?
Offline doylebros
  • -Receive: 310
« Reply #3 on: November 02, 2013, 08:59:00 pm »
Pressing buttons - watch a few videos on you tube using VCDS
Offline Andy1994
« Reply #4 on: November 02, 2013, 09:04:39 pm »
Il give it a go only ever used it for checking codes is there anything else i should be cheking?
Offline doylebros
  • -Receive: 310
« Reply #5 on: November 02, 2013, 09:46:40 pm »
Just start like I said watch YouTube but don't change anything just take the reading and you'll be fine :wink:
