Author Topic: Ticking noise, (in cabin) (((SOLVED)))  (Read 16317 times)
Offline skriller
« on: November 04, 2013, 10:03:26 pm »
Hey guys, not had the car long but only just noticed this.
i only noticed it happens when the engine is warm too(i tried it when it was cold again), its like a ticking noise that's constant but i can only hear it from inside and whilst idle.
anyway i found a video which is the exact same noise i can hear, anyone have any idea what it is? It seems as though the revs drop off slightly, if i touch the accelerator a tiny bit and bring the revs up it goes away.
just for clarity mine is a 07 plate Ed30, under warranty too.
:::TURN UP YOUR VOLUME:::
« Last Edit: December 17, 2013, 09:51:35 am by skriller »
DSG No.0106 T Red
Offline skriller
Re: Ticking noise Drivers side, (in cabin) >>with video<<
« Reply #1 on: November 05, 2013, 09:25:40 pm »
Knock knock..
>>Sent from outside my Ed30 :( <<
DSG No.0106 T Red
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #2 on: November 05, 2013, 09:38:32 pm »
Recirculation Flap Motor?
Offline doylebros
  • -Receive: 310
« Reply #3 on: November 05, 2013, 09:39:22 pm »
Isn't the ventilation motor fan failure - do a search on it you get some strange sounds when the fan gearbox fails!
« Last Edit: November 05, 2013, 09:58:09 pm by doylebros »
Offline skriller
« Reply #4 on: November 05, 2013, 10:07:02 pm »
but why would the noise go away if the accelerator is pressed to add a couple more revs?
thanks for the replies  :happy2:
DSG No.0106 T Red
Offline doylebros
  • -Receive: 310
« Reply #5 on: November 06, 2013, 04:49:41 pm »
Next time you're getting the car scanned do an output test on module 8 for the HVAC system.
This will test all the motors etc and you'll hear the noise then, if it's what we think it is.
Offline skriller
« Reply #6 on: November 06, 2013, 04:56:09 pm »
ok will do thanks  :happy2:
i really need to get VCDS at some point.. :ashamed:
DSG No.0106 T Red
Offline magicgilbert
« Reply #7 on: November 11, 2013, 09:45:12 pm »
I had a noise which I could only hear on tick over inside the car, with a bit of research I found out it was a clip that comes loose from the fuel pipe, it's located at the back of the engine drivers side. I'll take a picture when I get a moment. might not be that but solved the noise on mine, hope this helps mate
Torando Red ED30 num:1913 with stage 1 @ 296bhp
Offline skriller
« Reply #8 on: November 12, 2013, 11:21:45 am »
awesome thanks, i will have to have a look to see if i can find any loose clips around the engine.  :happy2:
DSG No.0106 T Red
Offline GTiBlues
  • Mr Blues
    • Bookface
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
« Reply #9 on: November 14, 2013, 04:40:16 pm »
Did you solve this? I got the same sound but not as loud.
Offline skriller
« Reply #10 on: November 14, 2013, 05:03:55 pm »
honestly im still looking into it.. i only get the weekends to fiddle with the car when its not pissing it down,
I looked in the engine bay drivers side and could not see or move anything that was loose, one plastic clip was loose but I doubt it was that.
I am gonna have a proper inspection this weekend, when the car is cold and warm, i will post the outcome, although for now it does seem to be intermittent... the noise comes and goes.
Does yours do the same or is it constant no matter what the conditions?
DSG No.0106 T Red
Offline ginge 0116
    • The kings cross hotel blackpool
« Reply #11 on: November 14, 2013, 06:02:38 pm »
Hey mate does this sound only come when the engine get up to temp if so I had the same issue and have now had it resolved. Let me know sam
Offline skriller
« Reply #12 on: November 14, 2013, 06:05:49 pm »
Yeah it did it when it was still warm, around 80-90.
DSG No.0106 T Red
Offline ginge 0116
« Reply #13 on: November 14, 2013, 06:44:43 pm »
Exactly the same as mine. Not cheap to get fixed though cost me just over 600 quid, but defo worth the money. Where are u based if near the midlands I can recommend the garage that did mine and another forum members car.
Offline LiamGTi
« Reply #14 on: November 14, 2013, 07:41:08 pm »
Great news mines also the same! £600 to fix. Havin' a laugh surely!
Whats the actual cause?
