Author Topic: Ticking noise, (in cabin) (((SOLVED)))  (Read 16342 times)
Offline skriller
Re: Ticking noise Drivers side, (in cabin) >>with video<<
« Reply #15 on: November 14, 2013, 07:41:21 pm »
Manchester, do you think it could be a warranty job as I only just got the car and it's under warranty...
>>Sent from outside my Ed30 :( <<
DSG No.0106 T Red
Offline Scrubadub
  • Soon to be "bagged"
« Reply #16 on: November 14, 2013, 08:02:06 pm »
Cam chain and tensioner?
Fun bags
Offline ginge 0116
    • The kings cross hotel blackpool
« Reply #17 on: November 14, 2013, 08:59:41 pm »
depends what type of warrenty u have I had insurance warrenty and wasnt coverd for it was a right load of s##t. So ended up paying forIit it would probably be best to speak to the place where u got it from. Even if they say that u need it diagnosing properly then might be best topay a garage to look at it, at least u can tell them what symptoms your having and where to look!
Offline GTiBlues
  • Mr Blues
    • Bookface
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
« Reply #18 on: November 14, 2013, 10:33:56 pm »
I read somewhere it could be the cambelt tensioner.
It does throughout all temps on idle, doesnt get any louder or quieter. Constant volume level. Cambelt kit is on my list of things to get done so will see.
Offline skriller
« Reply #19 on: November 15, 2013, 11:12:40 am »
well my cambelt is brand new and all parts surrounding it are new, i checked the list they did this just before i bought it.
no idea why i would have to fork out 600...  :scared:
DSG No.0106 T Red
Offline Scrubadub
« Reply #20 on: November 15, 2013, 07:36:15 pm »
Cam chain tensioner not cam belt tensioner, this is inside the engine
Fun bags
Offline Gide76
« Reply #21 on: November 15, 2013, 08:53:55 pm »
I had pretty much the same noise and read about the cam chain/tensioner issue on here. The chain is one the other side of the engine to the can belt to the right of the engine  as you look at the front of the car.
Had my local (and totally trusted) garage have a look. They took the engine apart, confirmed it was the chain and tensioner, ordered the parts from Vw and did the work.
No noise when done. They also did the cam belt and tensioner as it was nearly due and made sense for peace of mind and labour perspective.
Not saying it is the above but sounds similar.
Offline GTiBlues
  • Mr Blues
    • Bookface
« Reply #22 on: November 15, 2013, 09:48:07 pm »
Im going to order my list up on Tuesday down TPS, See if my staff discount will take a chunk of money off the prices lol Let you know the prices etc
Offline LiamGTi
« Reply #23 on: November 15, 2013, 10:10:24 pm »
Thanks mate, PM me the prices, because I'll forget to check in here again.
Offline skriller
« Reply #24 on: November 17, 2013, 09:04:26 pm »
UPDATE:
I spent all weekend in the car, as often as i could in silence, so i could hear any sounds.
Not a damn peep... car was as smooth and quiet as it would be brand new. Drove perfectly well and even had a Peugeot 208 GTi for breakfast.  :driver:
i have tested it hot & cold, with no other sounds other than the Climate control chugging every now and then.
so i have no clue what the ticking could have been at the time of hearing it.  :ashamed:
DSG No.0106 T Red
Offline LiamGTi
« Reply #25 on: November 28, 2013, 10:34:02 pm »
Mine is very intermittent,
Also my Climate Controls/Heaters do a fair but of chugging!
Offline skriller
« Reply #26 on: November 28, 2013, 10:41:41 pm »
It actually started ticking again before.. It sounds like something is loose.. But I can only hear it from inside the cabin.. No idea what it is.
The heaters and climate control are all normally chugging away and this noise comes and goes but for long periods... No idea what it is.
Vcds says it's clear so I dunno..
DSG No.0106 T Red
Offline doylebros
  • -Receive: 310
« Reply #27 on: November 29, 2013, 05:17:14 pm »
Do a search for fuel pipe rattles - common issue for your complaint!
Offline skriller
« Reply #28 on: November 29, 2013, 11:23:59 pm »
This is my actual sound now, after a good drive and on a warm engine only.
OOOOOOK
Rev counter is normal, doesn't dip lower or anything, but i have noticed that it does sound like it is revving lower and higher on its own as in hovering on a normal rev and a little lower rev. like breathing... that's the best way to describe it.. :stupid:
ill have a look under the hood tomorrow and make sure i look at all the pipes etc that i can get to, but i have no idea what this is.
DSG No.0106 T Red
Offline skriller
Re: Ticking noise, (in cabin) >>with NEW video<<
« Reply #29 on: December 05, 2013, 02:56:35 pm »
bump,
this is now a standard sound once the engine is up to temp...  :confused:
DSG No.0106 T Red
