Author Topic: Shark fin  (Read 969 times)
Offline sean140
Shark fin
« on: November 15, 2013, 03:46:41 pm »
My shark fin has finally arrived this week. So i will be  fitting it tomorrow.
Anyone on here done it before? Is there anything i should look out for or has any tips on doing this?
My aerial atm is perishing around the base so i thought i would change it for a shark fin. I will get some pics up after i have fitted it.
Offline doylebros
  • -Receive: 310
Re: Shark fin
« Reply #1 on: November 15, 2013, 04:53:16 pm »
If your mechanically minded and have short reach 22mm spanner, It's not hard but you've got to be careful with the headlining.
If it's just a change over that's it but the white aerial plug is taped to the roof so you need a mirror to find it!
However, if your fitting the Nav and Dab leads there's a bit more work involved.
Offline sean140
Re: Shark fin
« Reply #2 on: November 16, 2013, 09:06:04 pm »
Fitted the aerial fin today. Probably took me around 40 minutes in total. Wasn't as hard as I was thinking.
Had to improvise with the connectors as the 1 I bought wasn't the same fitting to the original connector.  Only issue I have is AM reception.  I have lost that now, not sure what is needed? Other than this I'm really impressed with the results.
Offline doylebros
  • -Receive: 310
Re: Shark fin
« Reply #3 on: November 16, 2013, 09:11:09 pm »
Well done - was the white connector tapped up to the roof?
Offline sean140
Re: Shark fin
« Reply #4 on: November 16, 2013, 09:16:17 pm »
It was taped.  Also behind the yellow airbag module (I think that's what it was) the aerial wire on the new fin was a bit shorter than the standard aerial. But all in all, very happy with it.
