Author Topic: I've killed something...............(update)  (Read 7436 times)
Offline Syrag64
Re: I've killed something...............(update)
« Reply #15 on: November 22, 2013, 03:31:01 pm »
Update on original post..................................
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
« Reply #16 on: November 22, 2013, 03:39:39 pm »
 :popcornsoda:
Offline Syrag64
« Reply #17 on: November 22, 2013, 03:44:15 pm »
Today I managed to finish work before it got dark and get underneath, the pendulam mount has broken/come undone and the engine has shifted forward about 2inches  :scared: :scared:
What damage could I have done?  I haven't lost any water or oil but a bit worried what I may have damaged that I cant see. :ashamed:
to save going all the way back to original post  :signLOL:
Offline xjay1337
  • -Receive: 377
« Reply #18 on: November 22, 2013, 03:52:36 pm »
If you've not lost anything then you've probably gotten away with it lightly. Just make sure the rads aren't damaged/bent and same for driveshafts. However cv joints should have taken up any slack.
Offline Syrag64
« Reply #19 on: November 22, 2013, 04:04:39 pm »
The alt belt has slight wear on it where it is touching something but I cant see anything obviously damaged, radiator wise. I will get car recovered and have it checked over & mounts replaced, will also get the LSD & new clutch fitted whilst i'm at it  :happy2:
Offline edd666999
  • -Receive: 89
« Reply #20 on: November 22, 2013, 04:38:36 pm »
Must have been one hell of a launch  :driver: :driver:
Offline xjay1337
  • -Receive: 377
« Reply #21 on: November 22, 2013, 04:48:30 pm »
Good lad!
Offline Syrag64
« Reply #22 on: November 22, 2013, 10:45:43 pm »
Looking at the mount thats broke/come undone i'm not sure if it was loose to start as it doesnt look broken it looks like a bolt has come out, i will try to get a picture over the weekend
« Reply #23 on: November 23, 2013, 06:41:49 pm »
Unless you have broken the other mounts then it wont have moved 2" forward.
Offline Syrag64
« Reply #24 on: November 23, 2013, 07:40:16 pm »
I will change them all just to be safe  :happy2:
Offline vRSAlex
  • -Receive: 253
« Reply #25 on: November 23, 2013, 09:00:12 pm »
When the mount breaks it can easily swing 2" forward and back, but as a swinging motion.  It will usually allow the aux belt to rub through the aircon pipe, possibly break the fan and may stretch the exhaust flexi. May also have stripped the threads from the gearbox.
The bolt must have been slightly loose. All the early cars pre 2010 used an 8.8 rated bolt, where after that it was changed to a 10.9 with a serrated washer fitted.
Follow AKS tuning on Facebook
Offline xjay1337
  • -Receive: 377
« Reply #26 on: November 24, 2013, 12:34:25 am »
Always buy/fit Polybush inserts..
Offline vRSAlex
  • -Receive: 253
« Reply #27 on: November 24, 2013, 08:48:09 am »
Wont stop the bolt snapping or coming loose though.  :booty:
