Author Topic: High pitched beeps  (Read 16037 times)
Offline Meallbhan
High pitched beeps
« on: November 20, 2013, 06:14:57 pm »
Evening all
The other day when I started the car, as soon as I turned the key, the car gave me 4 or 5 maybe 6 high pitched sharp beeps in very quick succession. I'm not sure but they seem to come from behind the dash.
The car did this before, 3 or 4 times maybe a year or so ago but I'd forgotten about it coz it didnt happen again. But it has now.
The car seems to be totally fine. Has anyone experienced the beeps or know what they are/mean?
Offline clapton712
Re: High pitched beeps
« Reply #1 on: November 20, 2013, 07:40:28 pm »
I'm guessing its the ice warning! Anything below 4 degrees it beeps away when you put the ignition on.
Offline john87
  • -Receive: 53
« Reply #2 on: November 20, 2013, 07:57:35 pm »
The 'bong' for low ambient temperature warning is just the one... could it possibly be the seatbelt beeper?
Offline Meallbhan
« Reply #3 on: November 20, 2013, 10:10:41 pm »
No its not the low temp warning, I know that one very well! Nor is it the seat belt bonger coz mine is unplugged.  These noises are totally different to my beeps though. My ones are high pitched, and if you say beepbeepbeepbeepbeep as fast as you can, thats quite close to how they are. Odd.
Offline Marc-5-GTI
« Reply #4 on: November 20, 2013, 11:47:10 pm »
Do you leave your car in reverse? Have you got reverse sensors? Are your friends handy with duct tape?
Offline edd666999
  • -Receive: 89
« Reply #5 on: November 20, 2013, 11:47:51 pm »
Are you getting older...could you be hearing things  :grin:
Offline Chrismeardon
« Reply #6 on: November 21, 2013, 08:46:47 am »
I've had this recently too. Very intermittent and seems to be coming from my head unit (the standard mk5 nav unit)
It reminds me of the noise aftermarket units make when a code is required.
Offline doylebros
  • -Receive: 310
« Reply #7 on: November 21, 2013, 08:54:32 am »
May be the cold weather is changing the sound but low outside temp is my vote or the cars haunted. :scared:
Offline xjay1337
  • -Receive: 377
« Reply #8 on: November 21, 2013, 09:18:37 am »
You will get a beep for any warnings from the dash cluster.
If you have low fuel, service light on and it's under 4 degrees you will get 3 beeps in a row.
Even though I've owned a Mk5 for 3 years it still always makes me panic a little if they come on when driving.
Offline Jaywoo-GTI
  • -Given: 38
« Reply #9 on: November 21, 2013, 09:21:00 am »
My old Audi A3(mk4 golf chassis) used to do this, It was something to do with the alarm,
or is your car fitted with a tracker, Could be a warning that the internal battery need replacing?
« Last Edit: November 21, 2013, 09:23:11 am by Jaywoo-GTI »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #10 on: November 21, 2013, 09:55:01 am »
Haha that happens to me too. Although mines only done 1 beep when under 4 degrees.
Offline xjay1337
  • -Receive: 377
« Reply #11 on: November 21, 2013, 10:12:12 am »
Yes, that is correct
I said if you have low fuel, need service and it's under 4 degrees, you'll get beep.
one beep per thingy.
Offline clubsport
« Reply #12 on: November 21, 2013, 01:56:18 pm »
I had this before with an Audi...it turned out to be the low battery in the alarm siren.
You often find this occurrs when the ambient temperature cools.
I only mention it as, Vw/Audi VAG etc....... Sorry I don't known if it is the same on a mk5 ?
Offline Meallbhan
« Reply #13 on: November 21, 2013, 06:04:58 pm »
Thanks for all the responses,
Ok, for definate I know its not low fuel, low temp, service needed or a reversing sensor (not fitted).
I thought too that it may be something to do with the stereo. But I don't think so now because it would be too much of a coincidence as I just changed the headunit a couple of months ago, and for the two units to make the same noise so randomly, nah.
The alarm was another choice of mine. Its just the standard alarm and there is no tracker fitted to the car. Where do I find the battery that could need changed? But again,  the beeps are so utterly random when they happen, I'm thinking the alarms battery is probably ok because the beeps would happen more often if it wasn't.
Someone above suggested the car could be haunted . . . .
I wonder what it could be?
Offline timwills17
« Reply #14 on: November 21, 2013, 10:32:29 pm »
Sometimes I pull off with hand break slightly on, very quick beeps are heard.
