Author Topic: Cam Follower Replacement - Pressure Release Banjo Bolt  (Read 10298 times)
Offline doylebros
  • -Receive: 310
Re: Cam Follower Replacement - Pressure Release Banjo Bolt
« Reply #15 on: December 10, 2013, 05:17:35 pm »
Give yourself plenty time - Slow and steady or don't start it!
The job is a nothing job really but if you strip any threads it will become expensive!
MPS
« Reply #16 on: December 10, 2013, 05:40:53 pm »
The whole design of the cam follower is crap to be honest. Hence VW changing it to a roller follower instead, still not a brilliant design in my eyes.
Offline Human Joist
« Reply #17 on: December 10, 2013, 05:47:52 pm »
Cool. Will wait till little one in bed then. Will plan to not replace the banjo bolt but have put car behind the others incase I need to buy it
Offline Human Joist
« Reply #18 on: December 11, 2013, 03:04:39 pm »
Right I changed my cam follower today and mine is the early two metal pipes. No issues at all pics of the old one bellow. From what I can see in the history it was the original one and as you can see started to show some ware but not as much as I thought.
When I did the two fuel lines the right one was no issue as we have all the same and know how to do that. The left one I undid the torx bolt from the bottom of the union. There did not appear to be any washers. Removed the bolt and changed the follower and then used the same one. From looking inside the hpfp there is a thread that it went in to and did not appear to have to cut its own. Little trick was to use a separate torx from another set and then slide a small adjustable spanner over it with some tape on the bottom to stop it falling out this making a small socket set up to allow access.
When you look at it the head of the bolt I removed is the round bit at the bottom underneath the joint on the left pipe. Hope that makes sense. Took half hour.
« Reply #19 on: December 11, 2013, 03:30:43 pm »
Hi gang
I've just changed my cam follower tonight and I have banjo bolt but pressure relief valve too.
It took about 40 mins and I found it an ok job. I did break to retaining clasp off the left hand cable connector on the pump so I had to bodge it in place with a self tapper for now  :scared:  I will order a new one.
See pics below for wear, Im presuming its the original on a 55 plate with 66k, blufin stage 1. Not too bad, but the hardened coating has worn so I'm presuming I changed it at the right time?!
Bodgetastic!!! :ashamed:
Looks very scratched. Was to oil ok?
Offline panarasgr
« Reply #20 on: December 11, 2013, 07:19:15 pm »
I am thinking to change my cam follower as well. Can anyone tell me what are the side effects of a failed cam follower? How can i understand that the follower has failed and it needs to be changed?
Golf Mk5 GTI DSG,APR Stage 2, K&N typhoon intake, Forge blow off,Revo PCV delete, 3'' Downpipe decat,
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #21 on: December 11, 2013, 07:22:53 pm »
Fuel cuts are a symptom.
'07 Red manual
Offline Human Joist
« Reply #22 on: December 11, 2013, 07:56:01 pm »
From what I understand if it fails it can write the engine off from secondary damage. For the sake of £25 for the part change it for piece of mind
Offline bellios
« Reply #23 on: December 13, 2013, 09:11:16 pm »
did this a few months back. Big tip, leave the drivers door closed. i left it open and it primed the in tank pump causing fuel to come out even after the fuse for the HPFP was removed.
the way i did it was to remove the fuse, run the engine till it stalls to remove fuel pressure, and then use the schraeder valve to remove the remaining pressure. The rest is quite simple after that.
Offline Human Joist
« Reply #24 on: December 13, 2013, 10:18:03 pm »
I left door closed and parked overnight. Opened bonnet through window and when I undid hpfp had just a dribble of fuel no issues.
