Author Topic: Rns 510 keeps rebooting several times (@startup) after fw update?  (Read 13149 times)
Offline doylebros
  • -Receive: 310
Re: Rns 510 keeps rebooting several times (@startup) after fw update?
« Reply #15 on: January 14, 2014, 06:58:52 pm »
Tried the fw0900 downgrade. But as expected it didn't help.
The rns510 rebooted one time before starting up this morning.
Guess I'm out of options....  :sad1:
It's only a thought but could it be a electrical connection problem at the back of the set?
Offline Timvgti
« Reply #16 on: January 14, 2014, 07:22:10 pm »
That is always a possibility but the reboots instantly occured after I did my first attempt updating to fw4020. So I guess not...
Offline Timvgti
« Reply #17 on: January 14, 2014, 07:23:45 pm »
Maybe a 'guru' as EddieNL knows what my reboot problem is?
I've pm'ed him.
Offline doylebros
  • -Receive: 310
« Reply #18 on: January 14, 2014, 07:38:56 pm »
Yes, good chance Ed will have seen this fault before.
However, you've put a lot of effort in to trying to correcting this, if it's a firmware fault I would of expected one of the installs you've been through to of corrected it! That's why I wonder if there's another fault which coincidently happened a the same time as the original firmware install?
Offline Chris01
« Reply #19 on: January 17, 2014, 09:05:44 pm »
Eh, I'm getting frustrated just thinking about it. So what's next? There was a DIY about replacing the OEM drive with an SSD, but it included taking the RNS down to bits..  :scared: It might be better to have it repaired after all.
Offline granpa1
« Reply #20 on: January 10, 2015, 08:46:52 pm »
Did have this on mine but mine would not start up at all, just reboot all the time. Mine was down to the firmware that had not taken correctly. Downloaded from a different source and all was good. Hope this helps.  :happy2:
Hi stephen..
I.know ur post was a very long time ago but im digging deep.in this.forum to.find the same problem as myn...
This.issue arised on the second day of buying my car and i got a qoute of 360 to reslove this.
Would you reccomend i.try this myslf and if so what is the procedure. And what.equipments will.i.need as im an amature to.all this... How do i update the firmware seen as my screen wont even switch.on?
I hope.u can help because im still recouping mg expendtiures spent to.purchase the gti and this.is the last thing i needed. Pure bad luck i guess seen as it was working fine.as i.drove back after purchasing it...
Hope you can help mate.
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
