Author Topic: Car idle speed raising on its own and dropping lumpy. Video  (Read 9195 times)
Offline smithyc1987
  • 08 Tornado red gti monza 2s and full leather.
« on: January 15, 2014, 07:41:36 pm »
As title my 2008 gti 55,000miles full vw history.
The idle keeps raising on its own then falling then repeating.
Heres a quick video,
Please excuse my daughter in the background.
Any help or ideas appreciated.
Saintsteve
Re: Car idle speed raising on its own and dropping lumpy. Video
« Reply #1 on: January 15, 2014, 07:56:44 pm »
Blown PCV valve  :smiley:
Offline doylebros
  • -Receive: 310
Offline smithyc1987
« Reply #3 on: January 15, 2014, 08:35:55 pm »
Cheers lads, easy/expensive fix?
Also the temperature dosent seem to get up to middle as easy sometimes and drops and rises
Offline doylebros
  • -Receive: 310
« Reply #4 on: January 15, 2014, 08:49:09 pm »
Read this (relevant section):-
http://www.mk5golfgti.co.uk/forum/index.php/topic,44709.0.html
20 minutes should sort it for the PCV valve.
The cooling temp may need to develop but there's a few interesting threads on cooling problems like this
http://www.mk5golfgti.co.uk/forum/index.php/topic,75756.0.html
Offline smithyc1987
« Reply #5 on: January 16, 2014, 12:54:45 pm »
Done the test and removed sipstick engine splutters when put back in all is well.
So not the pcv valve.
Throttle position sensor ?
It only seems to do it when warm
Saintsteve
« Reply #6 on: January 16, 2014, 06:20:14 pm »
Still PCV  :wink:
Offline smithyc1987
« Reply #7 on: January 16, 2014, 09:51:31 pm »
Y y y y ??????
Saintsteve
« Reply #8 on: January 17, 2014, 06:17:35 pm »
Y y y y ??????
If you've never replaced it, for the sake of £37 I would.
Offline smithyc1987
« Reply #9 on: January 18, 2014, 03:38:52 pm »
Also seems to be slightly running on for split second longer after ignition is switched off????
Saintsteve
« Reply #10 on: January 18, 2014, 06:23:26 pm »
Change it, and report back   :happy2:
« Reply #11 on: January 19, 2014, 12:46:31 am »
If you pull the dipstick out and it runs rough, and when you put it back in it still runs roughy it's the PCV.
I think Steve might have mentioned it once or twice already.  :laugh:
Offline smithyc1987
« Reply #12 on: January 19, 2014, 09:47:40 am »
No when i put dipstick back in it runs fine.
« Reply #13 on: January 19, 2014, 09:58:56 am »
Well if it runs fine then you dont have a problem!  :laugh:
Offline EddieA
« Reply #14 on: January 19, 2014, 10:11:31 am »
Exactly the same as what I had, sometimes it would do it and others it wouldn't. It's the pcv, change it and it'll be fine.
Edition 30 TTE420 - number 470 - RTech 418bhp and 391lbft
