Author Topic: Fitting later 3D style boot handle  (Read 6238 times)
Offline Simon_2.0t
« on: January 20, 2014, 11:08:33 am »
Hi guys, wonder if anyone can help or suggest how I can resolve this.
I am in talks with Simon (brookesb32) as the boot handle guru!  :notworthy: But we are still not sure how/why.
I have fitted a later 3D style boot handle to my 2005 golf to remove the whiteworm one. This sat flush but the new handle sticks out, looking at later 57 plate onwards golfs with this handle fitted as standard it sits flusher, and better than mine.
See pics below:
The handle in question. Standard one, not sure if missing anything around the base?
Badge sticks out about 5mm:
And from inside, the black locater is preventing me spacing the badge in further:"
Simon kindly send me some bolts from a later badge as well, cheers mate  :happy2: but still sits the same.
I thought about cutting the black tags off and then using some washers so the badge will sit more flush. Not ideal, plus think then will leak small amount of water in.
Hmmm. Maybe a later tailgate is different. if anyone has the rear trim off in the near future who has a 3D stype badge fitted as standard would they mine having a look how fits. Might have a shroud or trim bit I need.
Cheers Si
« Last Edit: January 20, 2014, 11:11:24 am by Simon_2.0t »
Offline v4rley
  • -Receive: 104
Re: Fitting later 3D style boot handle
« Reply #1 on: January 20, 2014, 12:21:35 pm »
I have a mk6 rvc badge, fitted to my 05 GTI and experience the same issue! I have just been living with it, as still looks better than the only white worn. Also looked at trying to space out with washer but no possible with the tabs. Not much help, but at least you know your not alone!
Offline marko
« Reply #2 on: January 20, 2014, 12:59:27 pm »
you'll only start getting water ingress if you try spacing the badge in...hence why there is a tab or locator fitted
just have to live with it
2007 TR gt170...heated leather,underseat drawers,auto-levelling bi-xenons,puddle leds,chrome switches,footwell lights f+r,cruise control and ed30 rear lamps,LED interior....carbon highline clocks,ed30 front spoiler,RNS 510 P+MDI,mk6 gti gearknob,TPMS done,complete r32 trim kit+ MFSW,r32 f+r brakes,RLS fitted.headlamp washers,folding mirrors and boot pop,mk6 RVC,19"Helios,AP coilies,valeo LEDs  ...dpf delete and remap to finish off
Offline Simon_2.0t
« Reply #3 on: January 20, 2014, 01:20:15 pm »
Cheers guys, are the tailgates different on 2007 Mk5 golfs?
Si
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #4 on: January 20, 2014, 01:53:46 pm »
Si
Yep we were both cofused on this one, my 55 plate did the same when I change the handle but another mates 56 plate was dead flush with his factory handle  :confused:
Offline Simon_2.0t
« Reply #5 on: January 20, 2014, 02:00:08 pm »
Si
VW must have changed the tailgates Si. Odd but only conclusion.
Not sure if to go back to flush non 3D now...
Si
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #6 on: January 20, 2014, 04:56:33 pm »
Si
Si
Noooooo :)
Offline JaseGti
    • Remoteclothing
« Reply #7 on: January 20, 2014, 05:34:11 pm »
Was thinking about doing my 05 with the mk6 badge but not sure now
Jase
CW is the way forwards
Remoteclothing.com
Offline Simon_2.0t
« Reply #8 on: January 20, 2014, 06:17:11 pm »
Si
Si
Noooooo :)
Think a Mk6 bsdge on this handle base will sit better? As I think they wrap round the edges more if that makes sense  :happy2:
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #9 on: January 20, 2014, 06:41:00 pm »
I can sell you a gloss black mk6 badge if you want one Si  :wink:
homesqueeze
« Reply #10 on: January 20, 2014, 07:18:13 pm »
Yeah mine sticks out like that too since I changed it on my '05. Still think it looks alright though.
Offline G40will
« Reply #11 on: January 20, 2014, 09:48:18 pm »
I fitted a complete Mk6 handle to mine and it sits flush...
Mines a 2006, I'm not sure what year the badge was from though...
Offline Simon_2.0t
« Reply #12 on: January 21, 2014, 10:05:53 am »
G40will, looks good mate. Is that a Mk6 badge on a 5 handle?
Si
Offline G40will
« Reply #13 on: January 21, 2014, 06:05:28 pm »
Si
It's a full Mk6 handle and badge mate, had to stretch the wires a bit but it just about reached. I must lengthen them next time I take the trim of the inside if the boot.
The red in fills are pre cut vinyl of eBay for about £1.50 posted!
Offline Luke s
« Reply #14 on: January 21, 2014, 09:48:33 pm »
 I've just fitted a mk6 badge to mine and it also sticks out. Tell me if I'm wrong but there are late mk5s with 3d badge and mk6 I believe mk6 is deeper I like it. G40Will if you trim the loom tape back where the lock wires and handle wires split there would be enough play to not need to stretch or lengthen them if you want to be anal like I was I re taped it with gen vw loom tape. Also would you be g40will from clubpolo? Used to go to the phirm red g40?
Luke
