Author Topic: RNS 510 issues!  (Read 3653 times)
Offline sparkyhughes
RNS 510 issues!
« on: January 25, 2014, 05:47:11 pm »
Just started fitting this and have a couple things!
1, it says theres an airbag ossue after ive fitted everything? Any idea?
2, I need an adaptor
3, is there a "how to guide" on how to set the bluetooth up?
And finally the volume up and down work on my steering wheel work not the next song option one!
Any help woth any will be greatly appreciated
thanks
Marc
Offline SI-R32
  • -Receive: 126
Re: RNS 510 issues!
« Reply #1 on: January 25, 2014, 05:52:30 pm »
you've probably turned on the ignition whilst the passenger airbag disengaged light in the vents was possibly disconnected?? you'll need either someone with VCDS or vw to reset the light
adaptors can be found all over ebay or possibly eddie-nl on here or car systems.pl
what do you need to know about bluetooth as its quite easy
and have you got the menu in the red mfd on audio for the up and down arrows to change track or radio station etc?
Re: RNS 510 issues!
« Reply #2 on: January 25, 2014, 06:32:07 pm »
Thanks Si! Bluebooth I heard wasn't just a plug and play :/ haven't really looked at it yet as it got dark! There doesnt seem to be an audio section any more on the mfd? :/
Offline SI-R32
  • -Receive: 126
Re: RNS 510 issues!
« Reply #3 on: January 25, 2014, 06:35:07 pm »
do you have vcds? before i carry on lol
Re: RNS 510 issues!
« Reply #4 on: January 25, 2014, 08:02:57 pm »
Sorry whats VCDS?  :ashamed:
Offline SI-R32
  • -Receive: 126
Re: RNS 510 issues!
« Reply #5 on: January 25, 2014, 08:07:18 pm »
vcds is the diagnostic tool to aid in lots of things,
I'm 100% sure your 510 will need a bit of coding done to remove a tick in a box called bap, this is why your menus aren't there anymore
also you need to tell the car that it has a bluetooth module installed
did you just by it all from ebay?
Re: RNS 510 issues!
« Reply #6 on: January 25, 2014, 08:13:45 pm »
No I got it off a lad off the other gti forum! Are these vcds tools expensive? If not is the coding simple and setting all the other parts up or not?  Why can't it just be simple haha
Offline SI-R32
  • -Receive: 126
Re: RNS 510 issues!
« Reply #7 on: January 25, 2014, 08:17:58 pm »
did he have a mk6?
you dont want to buy it just for that, have a look on here for vag com (vcds) locations hopefully theres someone near you that can code it up and cancel your airbag light for a beer :)
your not near kent are you?
Offline SI-R32
  • -Receive: 126
Re: RNS 510 issues!
« Reply #8 on: January 25, 2014, 08:20:42 pm »
actually while i'm on the subject what year is your car? do you know about battery drain issues pre 57 cars with the 510?
Re: RNS 510 issues!
« Reply #9 on: January 25, 2014, 08:21:32 pm »
No he took it out of a polo :/ didnt think it would make much of a difference :/ no I'm in hereford area! I will have a look (try) haha
I got 07 plate :/ will that have the problem?
Thanks a lot for all this by the way  :happy2:
Offline doylebros
  • -Receive: 310
Re: RNS 510 issues!
« Reply #10 on: January 25, 2014, 08:21:59 pm »
This is the list in question
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
I'm sure someone will help you out and if you want to read about VCDS go to Ross Techs site
Offline SI-R32
  • -Receive: 126
Re: RNS 510 issues!
« Reply #11 on: January 25, 2014, 08:31:17 pm »
i think with an 07 your going to get an issue matey, you might want to contact Eddie-NL on here he might do the modified firmware you can use (really cheap fix) or long term more expensive fix would be to change your can gateway.
how new was the polo as i'm still trying to get to the bottom of your menus going, i think i'm right though
Offline mvb12
  • -Receive: 64
Re: RNS 510 issues!
« Reply #12 on: January 25, 2014, 08:33:54 pm »
As stated earlier if you disconnected the airbag in the top vent then this is the reason why you have the airbag out.
simple reset with VCDS, just make sure you have plugged the connetor back in properly and it clicked back into place.
iirc pre 2007 mk5 models suffer from batter drain.
1 - if your running older FW on the RNS, do not update until you can get a newer CANBUS (if your car is pre 2007 or you will suffer.
2 - if you get any issues get a newer CANBUS. I can sort that out if you like. send me a PM :happy2:
Offline mvb12
  • -Receive: 64
Re: RNS 510 issues!
« Reply #13 on: January 25, 2014, 08:36:03 pm »
1 - if your running older FW on the RNS, do not update until you can get a newer CANBUS (if your car is pre 2007 you will suffer).
Re: RNS 510 issues!
« Reply #14 on: January 25, 2014, 08:47:20 pm »
He had a polo gti 6r?
Mvb12 I have pm'd you
