Author Topic: Advice needed  (Read 3553 times)
Offline Leigh200sx
Advice needed
« on: January 30, 2014, 08:43:40 am »
Hi there I'm looking at replacing my mfsw and heater controller for mk6 ones, question is will everything work straight away or will it need coding ..
Offline doylebros
  • -Receive: 310
Re: Advice needed
« Reply #1 on: January 30, 2014, 08:59:36 am »
Not sure on the steering wheel - would think no for that.
The heater control will depending on your year of manufacture to do some basic settings.
However, it would be best practice to scan your vehicle before and after any retro fit work,to check and clear DTCs and check all works as it should! :happy2:
Offline Leigh200sx
Re: Advice needed
« Reply #2 on: January 30, 2014, 09:26:12 am »
My car is a 2006 gti with factory options of a mfsw,cruise control,high line dash,dual zone climate and heated seats ...I am doing a deal with a local lad who has the mk6 ones fitted to his car but he is trading it in so wants my parts in the deal...
Offline doylebros
  • -Receive: 310
Re: Advice needed
« Reply #3 on: January 30, 2014, 12:21:21 pm »
Like I said the heater panel can be a pain if yours has the Econ/Ac button rather than Auto/Ac button for for climatic system!
Offline Leigh200sx
Re: Advice needed
« Reply #4 on: January 30, 2014, 05:41:41 pm »
My button says auto/econ??
Offline Leigh200sx
Re: Advice needed
« Reply #5 on: January 31, 2014, 12:10:04 pm »
Re: Advice needed
« Reply #6 on: January 31, 2014, 12:52:29 pm »
Doyle is slightly incorrect but basically right. Early VW Golfs had an Econ button than an AC button. The idea was the AC was always on unless you hit the ECONomy button, when it would turn off. Later changed to a simple AC button so you know when it's on and off.
Hence it will say ECON/AUTO or AC/AUTO.
Offline Leigh200sx
Re: Advice needed
« Reply #7 on: January 31, 2014, 01:31:22 pm »
My other mk5 has a different one again and it doesn't have  dual button??
Re: Advice needed
« Reply #8 on: January 31, 2014, 02:43:36 pm »
Pics? Does it have climate control?
Offline Leigh200sx
Re: Advice needed
« Reply #9 on: January 31, 2014, 03:48:41 pm »
Cte author=stealthwolf link=topic=78590.msg820201#msg820201 date=1391179416]
[/quote]
Yeah it has dual zone climate but you can't adjust the temperature together only one at a time..I'll get a picture later on
Re: Advice needed
« Reply #10 on: January 31, 2014, 04:39:29 pm »
Odd. I have seen pics of climate controls with no DUAL marking where the button normally is.
Offline Leigh200sx
Re: Advice needed
« Reply #11 on: January 31, 2014, 05:14:18 pm »
It's a early 2004 model probably one of the first ones
