Author Topic: Fitting Polar FIS +  (Read 22746 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
Re: Fitting Polar FIS +
« Reply #45 on: February 14, 2014, 09:40:25 pm »
I have also had a dodgy cable on a friends car
Over the top mod list ;o)
Offline bacillus
  • -Receive: 453
« Reply #46 on: February 14, 2014, 10:04:17 pm »
Yup, I suggested to Neil that this may well be cable or a cable connection issue...
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #47 on: February 14, 2014, 10:17:20 pm »
  :drinking:
Well tried as Romocop had suggested, that didn't work out, check all the wire's seems ok... but when i was sitting flicking through the highline dash options the radio was showing up diagnostics connected, as it does when the VCDS is scanning, a bit of a sharp noise, like a record scratching... :signLOL:
I also don't have a mfsw!
So could well be a dodgy cable, they do look fragile !
If it has a dodgy cable, can this cause battery drain?
Silver is the way !
Offline bacillus
  • -Receive: 453
« Reply #48 on: February 14, 2014, 10:35:36 pm »
Neil you sometimes see that  "diagnostics connected" at first start up of the polar.
I can't remember how you cycle through the various menu screens on your mfd (audio, settings, navigation etc) if you don't have a mfsw but can you please try doing so.
The polar desktop screen doesn't automatically show up when you first install the polar but once you display it and turn the ignition off, on restarting the polar desktop should re-appear as default.
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #49 on: February 14, 2014, 10:51:03 pm »
Will go try that now matey thanks  :wink:
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #50 on: February 14, 2014, 11:11:54 pm »
I only have the normal wipper stalk also, could this be why?
with the option to move up and down and with the ok button...
For some reason i don't get the option to flick through music or audio, only through the rns510 with using the sat-nav, it then allows me to skip songs!
 :confused:
Silver is the way !
Offline bacillus
  • -Receive: 453
« Reply #51 on: February 14, 2014, 11:29:20 pm »
Hmm, I have a feeling that because you can't seem to cycle through the various menu screens you'll not be able to access the polar desktop screen even though the polar is working correctly.
Have you double checked your car manual as I'm pretty sure the menu screen cycling can be done using the wiper stalk.
« Reply #52 on: February 14, 2014, 11:49:11 pm »
think by the sound of it you might need the mfsw-wonder if any member with a high line and mfsw is near you can try the polar on there carto see if it works
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #53 on: February 15, 2014, 12:08:17 am »
I can go through different options, but the polar is not one of them, i get driving time,avg speed, distance travelled, fuel range, avg fuel, current fuel, speed warning....
but don't seem to be able to access main options...
Yes had a read through the manual, i'm seem to be doing things right...
« Last Edit: February 15, 2014, 12:27:45 am by scopes »
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #54 on: February 15, 2014, 12:36:24 am »
I don't seem to be able to enter a menu options screen...
My high line was an after fit, 974 clocks if i remember correctly, is something missing?
long coding?
I'm near sure in my mates ed30, he can access different options than i can, but then i also think he has a different wiper stalk!
Silver is the way !
  • -Given: 243
  • -Receive: 155
« Reply #55 on: February 15, 2014, 03:12:08 am »
Shouldn't be a question about a stalk, i have the stalk you have with buttons for the menu, along with a afterfitted mk 6 MFSW and i can use both, as i have coded via VCDS the use of both.
Still sounds like the cable to me  :happy2:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=dnu48ld7bba3u8ui6h4bi1dn8q&/topic,19740.0.html
« Reply #56 on: February 15, 2014, 09:58:16 am »
Test the cable with an multimeter.
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #57 on: February 15, 2014, 03:42:05 pm »
 :drinking: cheers Jake
Well i took it out, checked the wires, re-loaded the polar box, but still not showing up on the screen.  I noticed when i hold the OK button in, i hear like a clicking noise coming from the polar box, then my RNS displays that "diagnostics connected"...
How did you code them in Jake?  I have the RS4 steering wheel, but have been unable to get using buttons, always wanted to see what the "S" button would do  :jumping: :signLOL:
Rich, I'm not up to multi-metering, so was unable to test that way... But i'm sure i could get someone too show me or test it for me...
I am now also able to scan the car with vcds, as it was not allowing me to do that before.
Saturday,15,February,2014,14:41:52:05378
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 75
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
75-Telematics -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 T    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: VWX7Z0G63NC8GC
   Coding: 0403000318070060
   Shop #: WSC 00191 264 15243
   VCID: 37797D98465886A6659-8062
1 Fault Found:
005696 - Internal Control Module
               P1640 - 008 - EEPROM Error
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 149678 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 10.0°C
                    Temperature: 9.0°C
                    Absolute Pres.: 900.0 mbar
                    Voltage: 11.430 V
Readiness: 0110 0100
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Component: ESP FRONT MK60      0102
   Revision: 00H13001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 71ED838068BC18966BD-8024
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 BE
   Component: ClimatronicPQ35 090 0808
   Shop #: WSC 00000 000 00000
   VCID: 6BD191E84A90F246511-803E
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000003741322
   Coding: E58F8F2700041800001400001400000000087F075C
   Shop #: WSC 00000 785 00200
   VCID: 2B5151E88A103246111-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00065493
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00207646
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: 38 AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD046H1V
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3B7161A87A70A2C6811-806E
   Subsystem 1 - Serial number: 6332MSME0D453C5DQ
   Subsystem 2 - Serial number: 6342MSME0D535D7BT
   Subsystem 3 - Serial number: 6352QSME02512F67F
   Subsystem 4 - Serial number: 6362QSME033B0A0BG
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 634 0070
   Coding: 0000012
   Shop #: WSC 00898 000 00000
   VCID: 76E7B09C01D23FAEBEF-8023
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 972 E
   Component: KOMBIINSTRUMENT VDD 4312
   Coding: 0005403
   Shop #: WSC 26086 444 52293
   VCID: 34634A94572E6DBE40B-8061
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 310512F2001517
   Coding: 350001
   Shop #: WSC 12345 123 12345
   VCID: 3F8915B8AE68BEE6AD9-806A
1 Fault Found:
01331 - Door Control Module; Driver Side (J386)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 72
                    Mileage: 149679 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:40:00
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 D    HW: 1T0 035 680 B
   Component: RNS-MID       H03 3810
   Revision: AB001001    Serial number: VWZ6Z7H6184085
   Coding: 080004000400001800
   Shop #: WSC 00020 790 12345
   VCID: 2F6945F87E084E663D9-807A
1 Fault Found:
00856 - Radio Antenna
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 32
                    Mileage: 149672 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:04:46
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2390
   Coding: 0000564
   VCID: 3667709C41527FAE7EF-8063
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 00903 210 57712
   VCID: 356577905C5474B6775-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0202
   Revision: 00020000    Serial number: 00000000000000
   Coding: 98900A085103487F000285057008DA06009840
   Shop #: WSC 06441 785 00200
   VCID: 83015948C2009A06091-80D6
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 72
                    Mileage: 149679 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:40:00
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Coding: 0000564
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
1 Fault Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 32
                    Mileage: 149672 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:04:46
Address 75: Telematics
Cannot be reached
End   ---------------------------------------------------------------------
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #58 on: February 15, 2014, 10:48:33 pm »
Have a highline dash clocks and have had them fitted and coded, they are working, I don't have a MFSW only the wiper stalk, when I press and hold the up or down buttons no menu comes up. If I press it then i can change through the MPG, AVG speed, just no menu, and also it doesn't display the audio I am listening to - have an RNS 510, but when i use the sat nav, the sat nav comes on the highline dash ok!
I have been looking for ways to code or add in the wiper stock, anyone any ideas?
thanks
Silver is the way !
Offline skard
  • -Receive: 245
« Reply #59 on: February 15, 2014, 10:56:01 pm »
You've got 972 clocks so really speaking you will need a MFSW with the 'later' buttons that specifically have a Menu button.
