Author Topic: Brake booster part number needed  (Read 7618 times)
Offline ChrisGti
« on: February 19, 2014, 03:24:05 pm »
Hi Guys, Figure I need a new brake booster hose as mine hisses after the engine is switched off and has around 3mm of wobble in/out. :scared:
Would anyone have the part number and wheres the best place to get a new one?
Offline bacillus
  • -Receive: 453
Re: Brake booster part number needed
« Reply #1 on: February 19, 2014, 03:35:33 pm »
Are you meaning this?
Offline ChrisGti
« Reply #2 on: February 19, 2014, 04:09:12 pm »
That's exactly what I need
Offline bacillus
  • -Receive: 453
« Reply #3 on: February 19, 2014, 04:24:29 pm »
Latest revision part number is 1K0612041GM
Offline doylebros
  • -Receive: 310
« Reply #4 on: February 19, 2014, 04:27:47 pm »
£28.82 full retail inc vat is that helps?
Offline bacillus
  • -Receive: 453
« Reply #5 on: February 19, 2014, 04:31:04 pm »
Chris if you around the Manchester area I have an unused previous version number hose without the connecting rubber hose available. It is exactly like the latest version.
Offline ChrisGti
« Reply #6 on: February 19, 2014, 04:42:40 pm »
Thanks guys and Im up in the chilly Newcastle so bit far from Manchester.
Best place to get this hose from other than VW parts desk?
« Last Edit: February 19, 2014, 04:49:15 pm by ChrisGti »
Offline doylebros
  • -Receive: 310
« Reply #7 on: February 19, 2014, 04:44:27 pm »
TPS in Byker!
Offline ChrisGti
« Reply #8 on: February 19, 2014, 04:50:54 pm »
I didnt think TPS was open to the public????
Offline doylebros
  • -Receive: 310
« Reply #9 on: February 19, 2014, 04:52:03 pm »
Ask for Neil Hamilton he'll sort it!
Offline PirelliDroo83
« Reply #10 on: January 10, 2017, 10:36:43 pm »
Old thread revival.....
I've been told the check valve on my brake booster hose is failing to close under boost so I'm after a new one.
However, this is proving very difficult as the guys at my VW Parts Dept cannot find the correct part for my engine.
When I give them either the 1K0 612 041 BM or GM revision part numbers they are not listed against my BYD engine code, infact when they show me the parts catalogue on their screen there are no parts with the three pipes coming off the valve, only ones with two.
Also, my one that is failing doesn't have the very short pipe coming off to the right like the one in the photo above has.
Do all Pirellis / ED30s have the BYD engine code?
Would any BYD owners be able to check what part number they have on their cars for me please? It would be greatly appreciated.
« Reply #11 on: January 13, 2017, 07:56:48 am »
Bump.
Is anyone able to help with this?
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #12 on: January 14, 2017, 11:59:43 pm »
All Pirellis have BYD engines.
Offline barelyrelevant
« Reply #13 on: January 15, 2017, 02:18:04 pm »
I'm confused, if the one on your car at the moment doesn't have the little nipple on the right side of the valve in the photo then don't you need one with two pipes coming off the valve?
« Reply #14 on: January 16, 2017, 07:35:03 pm »
This is the part number for my one which does not have the little third nipple coming off the check valve.
1K0612041BM
Hope that helps.
Edit: After a bit of Googling (as I'm also looking to buy this part), it was superseded with 1K0612041CH which does not have the nipple, but this has also been superseded by guess what 1K0612041GM, which has the friggin' nipple on it.
« Last Edit: January 16, 2017, 07:43:05 pm by barelyrelevant »
