Author Topic: WHITE Headlight Bulbs  (Read 3632 times)
Offline chrisr763
  • -Receive: 62
« on: February 21, 2014, 12:20:53 pm »
Hello!
I am well aware there are several threads regarding bulbs throughout this forum - However none actually help when looking for the whitest bulb to (try) and match LED sidelights.
Does anyone have experience of H7 halogen bulbs that are of good performance and show a white light?
I am currently running Phillips x-treme bulbs...
These look positively yellow next to my sidelights - They are however a very good bulb and give very good visibility.  :happy2:
Thanks for your help!
Chris
Offline xjay1337
  • -Receive: 377
Re: WHITE Headlight Bulbs
« Reply #1 on: February 21, 2014, 12:23:19 pm »
Phillips diamond bright or something. it's advertised as 5k halogen bulb not for road use.
You can't physically get a halogen bulb to match a white LED side light.
homesqueeze
« Reply #2 on: February 21, 2014, 02:09:36 pm »
I've got the same issue! I have the Philips X-treme vision as well. Great bulb, but now I've changed to LED sidelights they do look yellow. You can get bulbs with a blueish look to give a Xenon style look. They might make a better match but they won't have the same performance as the X-treme vision. I am debating what to do myself but might just live with the different colour combo.
Offline chrisr763
  • -Receive: 62
« Reply #3 on: February 21, 2014, 02:17:47 pm »
I know J but I can dream  :grin:
Thinking just get some projector headlights and run HID's eventually. Looking for a second hand set  :smiley:
Offline south
« Reply #4 on: February 21, 2014, 02:27:33 pm »
Been trying to get a certified question to my newbie question... are the philips simply plug and play into a stock car?
homesqueeze
« Reply #5 on: February 21, 2014, 04:35:19 pm »
The X-treme vision are a straight swap yep. I just got my headlight alignment checked after to make sure it hadn't altered. Also, don't touch the bulb glass with your fingers  :happy2:
Offline south
« Reply #6 on: February 21, 2014, 05:57:08 pm »
I went out and got a set of Philips before reading the post and chanced it, turns out I had Osram 64210's installed (no idea what model this relates to after a quick google), can't tell much of a difference (see pic below - philips on drivers, osram on passenger), might take them back.
« Last Edit: February 21, 2014, 05:59:06 pm by south »
homesqueeze
« Reply #7 on: February 21, 2014, 07:37:31 pm »
You won't necessarily notice the difference by just looking at them. You need to go for a good drive in the dark and more powerful lights will be noticeably better lighting up the road by shining further ahead.
Offline south
« Reply #8 on: February 21, 2014, 09:06:50 pm »
I have done, still not a noticeable difference - but then I apparently wasn't on stock before
homesqueeze
« Reply #9 on: February 21, 2014, 10:01:47 pm »
I see, fair enough.
Offline letlifeburn
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,79128
« Reply #10 on: February 21, 2014, 10:29:15 pm »
You had these ones, same as what was in mine before I put the night breakers in tonight. Im guessing with Osram being a german brand, they're just standard in the VAG group. I aint used the philips xtremes but the night breakers i noticed a massive different, even in the pics i took of before and after you could easily see it.
http://www.osram.com/osram_com/products/lamps/automotive-lamps/automotive-cars/halogen-headlight-lamps-for-cars/osram-original-line/index.jsp?productId=ZMP_61232
Offline MJ
« Reply #11 on: February 22, 2014, 12:28:46 am »
i run osram night breaker ultra +110% bulbs in my main beam and fogs along side led sides and hid dipped beam in projector headlights. it makes for a decent combo.
2005 VW Bora TDI 130 Highline auto. Current mods: 5.5lt washer bottle & black and aluminium A/C knobs & 312mm front brakes and 256mm vented rear brakes.
Next: turborevs SMIC, 20vt pancake pipe and silicone connectors.
VCDS, ODIS, VAS - PC and multi brand diagnostics around Manchester - pm me for help and advice
