Author Topic: Air Con Compressor Help  (Read 1687 times)
Gobytibbs
« on: February 24, 2014, 04:12:55 pm »
Hi Guys,
I have a faulty air con compressor on my GTi and I cannot get to the part number in the engine bay! I have been to the stealers and managed to get hold of 2 part numbers that came up under the VIN number for my car.
1k0 808 820 dx
1k0 808 820 fx
I understand this is quite a common fault with the MK5 and was hoping that somebody else may have been through this process before and could shed some light on the correct part number so I dont have to remove the front end twice to get it repaired!
Any help would be much appreciated  :smiley:
Gobytibbs
Re: Air Con Compressor Help
« Reply #1 on: February 25, 2014, 06:04:34 pm »
Bump
Gobytibbs
« Reply #2 on: February 25, 2014, 06:06:24 pm »
A little more info.. The air con compressor wouldnt hold any gas. The guy at the garage said that a seal had gone on the compressor and that it needed replacing. Anyone else had this issue?
Offline doylebros
  • -Receive: 310
« Reply #3 on: February 25, 2014, 06:13:29 pm »
My starting point would be the high pressure switch and seal - the compressors are weak but the switch and regas is cheaper!
The switch is located on the aircon pipework just around the alternator area - the switch in question goes porous .
This is the item
http://www.ebay.co.uk/itm/Audi-Volkswagen-A-C-Pressure-Switch-Genuine-OE-1K0959126A-NEW-OEM-VW-/121155172906
Would replace that and the seal around £40ish if I remember correctly.
« Last Edit: February 25, 2014, 06:24:22 pm by doylebros »
Gobytibbs
« Reply #4 on: February 25, 2014, 06:55:09 pm »
Fantastic, thank you  :happy2:
