Author Topic: how on earth do you get the can gateway out?  (Read 2187 times)
Offline paul_mck
« on: February 25, 2014, 09:47:23 pm »
mine is buried up above the clutch pedal right up behind the instrument cluster. any tips on getting it out? I could just about get my fingers to it.
any help appreciated!
Offline doylebros
  • -Receive: 310
Re: how on earth do you get the can gateway out?
« Reply #1 on: February 25, 2014, 09:54:21 pm »
This is worth a read
http://www.mk5golfgti.co.uk/forum/index.php/topic,47405.msg589543.html#msg589543
Through the engine bay - wipers out etc access in 15 mins in and out.
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #2 on: February 25, 2014, 09:57:40 pm »
Just like Ed says:
Above The clutch Pedal
Undo the 2x Torx screws of the drivers footwell trim and lower it down.
The Cubby bin under the light switch, nip the sides in and pull it towards the drivers seat. You will see a Torx screw that holds the lower duct pipes in place, remove the screw and pull the ducting out.
The gateway will be up and look for the RED Plug
Unplug it
Prise the Plastic holder away from the metal frame with a slotted screwdriver
and remove it with the gateway in place.
Change the gateway over and reset the plastic rivet which held the holder in place.
And refit it
Just need some patience with this, if in doubt, stop and have a cuppa  :wink:
Silver is the way !
Offline doylebros
  • -Receive: 310
« Reply #3 on: February 25, 2014, 10:07:18 pm »
Just like Ed says:
Unplug it
And refit it
The method above is for those flexible type for the none flexible type use this
http://www.r32oc.com/topic/29242-canbus-gateway-location-removal/
Offline marko
« Reply #4 on: February 25, 2014, 10:30:52 pm »
Scuttle panel
Wiper motor
2 nuts
Boom!!!...
You get to keep the skin on yer knuckles this way..lol
2007 TR gt170...heated leather,underseat drawers,auto-levelling bi-xenons,puddle leds,chrome switches,footwell lights f+r,cruise control and ed30 rear lamps,LED interior....carbon highline clocks,ed30 front spoiler,RNS 510 P+MDI,mk6 gti gearknob,TPMS done,complete r32 trim kit+ MFSW,r32 f+r brakes,RLS fitted.headlamp washers,folding mirrors and boot pop,mk6 RVC,19"Helios,AP coilies,valeo LEDs  ...dpf delete and remap to finish off
Offline paul_mck
« Reply #5 on: February 26, 2014, 07:48:12 am »
scuttle panel looks the job cheers guys!
Offline SI-R32
  • -Receive: 126
« Reply #6 on: February 26, 2014, 08:10:35 am »
only problem with doing it that way is the wipers can be an absolute bitch to get off as they corrode onto the spline, once these are off its all plain sailing.
Offline SRC
  • -Receive: 27
« Reply #7 on: February 26, 2014, 06:44:27 pm »
Call a gynaecologist?
Shadow blue DSG 5 door with leather, sunroof, 18" Monzas, MFSW.
Full list of mods:  Seat inserts and a VW bottle opener.  Each worth 20bhp.
