Author Topic: Side impact sensor  (Read 15620 times)
Offline J12spk
  • VW PERVERT
Side impact sensor
« on: February 28, 2014, 05:30:29 pm »
Guys, got an airbag light on. Had a scan as it's showing intermittent fault on drivers side crash impact sensor. Guna order a new sensor but before I rip the car apart, can any1 tell me the part number and location...........
James
Das Auto
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: Side impact sensor
« Reply #1 on: February 28, 2014, 05:35:59 pm »
Was it a VCDS Scan - if it was it will give you the part number.
The side impact sensor it under the doorskin
Offline J12spk
  • VW PERVERT
« Reply #2 on: February 28, 2014, 05:37:34 pm »
Ah I did not realise that!!! And it's defo under the door skin? Might coincide that with the fitting of my chrome tipped fuel cap switch!
Das Auto
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #3 on: February 28, 2014, 05:39:02 pm »
I'm sure it is but just trying to find webpage i had in mind to confirm.
Offline J12spk
  • VW PERVERT
« Reply #4 on: February 28, 2014, 05:41:21 pm »
I've got a 3 door, 2005 1.9tdi if that makes any difference?
Das Auto
Offline SI-R32
  • -Receive: 126
Re:
« Reply #5 on: February 28, 2014, 05:41:57 pm »
Yes its under door skin mate, plus it may not be sensor wire might be nearly broke between car and door?
its the blue sensor in the middle of the door
« Last Edit: February 28, 2014, 05:49:49 pm by SI-R32 »
Offline Beddie
  • -Receive: 76
« Reply #6 on: February 28, 2014, 06:05:47 pm »
I'd also check the wiring in the door bellows, done 2 cars now (mk5 golf and an Octavia vrs) that had airbag lights on with the side crash sensor showing as the cause in VCDS, both were due to broken wiring within the door to body loom  :happy2:
Carbon Grey Edition 35 - Here
Offline doylebros
  • -Receive: 310
« Reply #7 on: February 28, 2014, 06:15:59 pm »
Check the scan and if the number matches this may help but I feel the last posters comment would be my first choice!
If it is the sensor 1K0 955 557 B - £51:76 full retail inc vat
Or this may be better route
http://www.ebay.co.uk/itm/GENUINE-VW-GOLF-JETTA-PASSAT-SEAT-LEON-G179-AIRBAG-PRESSURE-SENSOR-1K0-955-557-B-/400669906684?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d49c996fc
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #8 on: February 28, 2014, 06:21:37 pm »
Second that. My door lock doesn't always unlock using the remote and it looks like i have a couple of broken wires in the loom. I have yet to order one but i know its going to set me back £80ish to replace it  :fighting:
Offline SI-R32
  • -Receive: 126
« Reply #9 on: February 28, 2014, 06:26:43 pm »
its only ever going to be in the rubber bellows, so i'd just patch new cables in between say 8 inches in the door and the plug, solder it all up job done, no need for new loom mate
Offline J12spk
  • VW PERVERT
« Reply #10 on: February 28, 2014, 09:09:16 pm »
Cheers guys, I've got no problems with locking or anything else! The light came on randomly, reset on vagcom then lasted a week a came back on. Is that a sign of damaged wires or dodgy sensor? Is it best to remove the outer skin or can it be done from the inside with the door card off?
Das Auto
Offline SI-R32
  • -Receive: 126
Re:
« Reply #11 on: February 28, 2014, 09:11:56 pm »
You won't ever know without deduction,  you need to get wires checked first, cheapest option, then if OK its the sensor
Offline J12spk
  • VW PERVERT
« Reply #12 on: February 28, 2014, 09:14:58 pm »
Fair one, thanks again mate
Das Auto
Offline SI-R32
  • -Receive: 126
Re:
« Reply #13 on: February 28, 2014, 09:18:23 pm »
You need to remove both really, door card off to drill out rivits then skin off to get to either the wires or sensor
Offline J12spk
  • VW PERVERT
« Reply #14 on: February 28, 2014, 09:20:18 pm »
Ah, not a particularly easy job then  :sad1:
Das Auto
