Author Topic: Ipod connectivity???  (Read 1321 times)
Offline Jayy26
« on: March 05, 2014, 03:31:16 pm »
Hi im wanting to be able to play songs in my car either by aux cable or from a cable like MDI
i dont have £80-£100 to spend on a proper one..:/
so whats peoples experience  with the connects2 or other variations, can someone link me a decent one
i do like my music to be clear aswell :)
http://www.ebay.co.uk/itm/251074271498
http://www.ebay.co.uk/itm/VW-VOLKSWAGEN-PASSAT-3-5mm-AUX-INPUT-ADAPTOR-MP3-LEAD-iPod-iPhone-RCD300-RCD500-/151238974664?pt=UK_In_Car_Technology&hash=item23368b9cc8
Offline Jayy26
Offline Dave7692
Re: Ipod connectivity???
« Reply #2 on: March 05, 2014, 04:07:04 pm »
If you're using an ipod touch/iphone Griffin do an excellent FM transmitter that you tune through an app you have on the phone/ipod and it has skip/play/pause buttons on the cigarette lighter which is useful.
i have one and its very clear, the app has a autotune feature which detects the cleanest frequency in your area.  I think I got mine for about £25.
Offline Jayy26
« Reply #3 on: March 05, 2014, 04:10:54 pm »
wow thats pretty cool but never really fancied the fm transmitter never seem to work with me :(
they just on ebay or what?
Offline Dave7692
« Reply #4 on: March 05, 2014, 04:16:26 pm »
Thats the one I have, its pretty good, you get the odd patch when it gets a little fuzzy but not often (usually happens to me because I have to go over a massive hill to get to work) however after trying 2 different frequencies I found it works almost perfectly.
http://www.amazon.co.uk/Griffin-GA22050-Connect-Control-Through/dp/B004A91HZO
Offline Jayy26
« Reply #5 on: March 05, 2014, 04:54:14 pm »
cheers  :drinking:
dont know if i would want it sticking in fag lighter all time #:/
Offline Dave7692
« Reply #6 on: March 05, 2014, 05:01:04 pm »
Yeah thats fair, I'll probably end up upgrading my head unit eventually as I want a built in sat nav, I just thought I'd share that as a cheaper alternative for you, I think theres a few people who have retrofitted ipod AUX inputs on here.
Offline timwills17
« Reply #7 on: March 05, 2014, 05:28:21 pm »
Bought and fitted the connects2 to the cd changer port on the rcd300! Quality is Great like CD quality!
Offline sean76
« Reply #8 on: March 05, 2014, 08:22:22 pm »
X2 for the connect2. Think I paid £40. IMO the sound quality is better than cd and you can whack it up fairly loud. I ran mine
Down the back of the heater controls and out so that it sits on top of the ashtray. Not very Oem I know but it stops you forgetting to remove your iPod so thieving types don't pop a window to get at it. I had to cable tie the plug to the box coz it kept falling out but have no other problem with this set up.
Offline Jayy26
« Reply #9 on: March 13, 2014, 05:17:23 pm »
bought one off amazon for 35 and it charges and has a spare AUX aswell :D
Offline Woldddd
« Reply #10 on: March 13, 2014, 08:42:41 pm »
I originally had the rcd300 headunit wired with the connect2, but the connect2 ideally to be wired up to the 12V power outlet otherwise it will always be on and drain the battery, But then I changed my headunit to the rcd310 with aux enabled which in my opinion is a lot nicer and more modern, if the rcd310 is fitted to a pre 2008 vehicle you will need the canbus adapter to prevent battery drain, luckily I was ok and didn't need one as mine is a 57/08 plate golf I then bought the aux cable that wires in the harness in the back of the headunit and it works a treat, I'd be inclined to buy the rcd310 with aux headunit as it isn't that much and then purchase the aux cable I bought, Sorry for the long winded answer, just thought It might be something to consider as im glad I took the new headunit route.
Links to :-
Headunit: http://www.ebay.co.uk/itm/VW-CD-PLAYER-RCD-310-CD-RADIO-GOLF-PASSAT-TOURAN-JETTA-EOS-WITH-CODE-/181339226902?pt=UK_In_Car_Technology&hash=item2a38a90316
Aux cable: http://www.ebay.co.uk/itm/Volkswagen-RCD210-RCD310-RCD510-Aux-Input-Adaptor-Audio-Interface-Converter-/400557803253?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d431b06f5
