Author Topic: Common Faults & Mileage  (Read 2707 times)
Offline zenicman9
« on: March 06, 2014, 09:18:18 pm »
Hey Guys
Last thread I promise :)
What are the common faults I should be looking for with a GTI that has covered 80,000 or more miles?
Offline Marc-5-GTI
Re: Common Faults & Mileage
« Reply #1 on: March 06, 2014, 11:04:36 pm »
They blow up at 80,001  :wink:
Nah,
Just check the usual stuff covered all over the forum..
DSG services
Etc
Etc
And the Usual things when buying used cars..
Gobytibbs
« Reply #2 on: March 07, 2014, 06:11:40 am »
Rust around the front wings caused by foam. Currently having mine repaired, quite a common problem. Also check the air conditioning, switches, compressors etc are prone to failing too.
Offline Stevepd
  • -Given: 49
« Reply #3 on: March 07, 2014, 06:36:35 am »
Slow warm up or fluctuating temp gauge.
Standard 5 Door Shadow blue.
Offline sean140
« Reply #4 on: March 07, 2014, 08:52:03 am »
I'm also on the hunt for a GTI as well, So this is useful for me!  :happy2:
homesqueeze
« Reply #5 on: March 07, 2014, 05:03:56 pm »
The rubber tears on the diverter/dump valve after a while. If it doesn't feel like its boosting properly then its probably this.
Offline driver rider
  • -Given: 18
« Reply #6 on: March 11, 2014, 06:17:01 am »
Check the  air con take it to warm and then down to cold and back again to male sure its working.  three doors apparently can let water in so check seals, check airbag lights.
Make sure cambelt and DSG services have been done.  I prefer a car serviced at least annually not the variable service schedule.
3 Door GTI Black, Cruise Control, DSG, Factory Tints, Folding Mirrors, Heated Seats, Highline Display, Leather, Monza II's, MFSW, Parking Sensors, Puddle Lights,  Xenons,
To be fitted....Bluetooth,DVB-T, MDI, RNS510, Stage one (opinions much appreciated)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #7 on: March 11, 2014, 07:40:21 am »
Rust in rear hatch, rust in the C pillar where the seal from the rear doors can damage the paint (5 doors), rust on the panel below front wings.
Over the top mod list ;o)
Offline Human Joist
« Reply #8 on: March 11, 2014, 08:01:01 am »
Also check the rear tyres. Mine were sawtoothed due to the rear parts failing. Can't remember exact name. But from looking under rear of car in the middle there are too large figure eight links holding the back together. Can't miss them when looking. They tie the back together. Simple to change. As the rubber fails the track fails and scrubs the tyres. The parts were about £80 and obviously two tyres also. Check in inside of the rear tyres to detect this.
