Author Topic: ESP Light Wont Turn Off?!  (Read 6151 times)
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« on: March 10, 2014, 09:23:07 am »
For some strange reason my ESP light randomly come on last night and wont turn back off. Anyone got any ideas what the problem could be?!
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
Offline xjay1337
  • -Receive: 377
Re: ESP Light Wont Turn Off?!
« Reply #1 on: March 10, 2014, 09:30:31 am »
Probably ABS pump... scan the car?? Would seem to be the logical first step ;)
Offline marko
« Reply #2 on: March 10, 2014, 09:57:43 am »
Happened mine about 6 weeks ago..
Needed new abs module...around 200 pounds all in
As above get a scan..anything with brake pressure sensor(g201) is the module which is best dumped and get another one
2007 TR gt170...heated leather,underseat drawers,auto-levelling bi-xenons,puddle leds,chrome switches,footwell lights f+r,cruise control and ed30 rear lamps,LED interior....carbon highline clocks,ed30 front spoiler,RNS 510 P+MDI,mk6 gti gearknob,TPMS done,complete r32 trim kit+ MFSW,r32 f+r brakes,RLS fitted.headlamp washers,folding mirrors and boot pop,mk6 RVC,19"Helios,AP coilies,valeo LEDs  ...dpf delete and remap to finish off
Offline vr6 g3
« Reply #3 on: March 15, 2014, 09:48:05 pm »
If you're local to Doncaster I'll plug it in for you
Offline SI-R32
  • -Receive: 126
« Reply #4 on: March 15, 2014, 09:56:09 pm »
we have scanned it hopefully this might be helpful
VCDS Version: Release 12.12.2
Data version: 20140212
Saturday,15,March,2014,16:19:40:44907
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 T    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: VWX7Z0G43NE91W
   Coding: 0403000318070060
   Shop #: WSC 107523 944 00281
   VCID: 37794E6A46E2EFA66AD-8062
4 Faults Found:
000051 - Turbocharger Bypass Valve Control Circuit
               P0033 - 004 - Malfunction / Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 12
                    Reset counter: 255
                    Mileage: 112939 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:27:18
             Freeze Frame:
                    RPM: 757 /min
                    Load: 15.7 %
                    Speed: 2.0 km/h
                    Temperature: 81.0°C
                    Temperature: 22.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.970 V
001056 - Catalyst System; Bank 1
               P0420 - 002 - Efficiency Below Threshold - MIL ON
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 112944 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:36:07
             Freeze Frame:
                    RPM: 2382 /min
                    Load: 11.4 %
                    Speed: 48.0 km/h
                    Temperature: 77.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.224 V
008801 - Boost Pressure Control Valve (N249)
               P2261 - 008 - Mechanical Malfunction - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 36
                    Reset counter: 255
                    Mileage: 112946 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:41:51
             Freeze Frame:
                    RPM: 3125 /min
                    Load: 7.4 %
                    Speed: 107.0 km/h
                    Temperature: 81.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.224 V
000564 - Boost Pressure Regulation
               P0234 - 001 - Limit Exceeded (Overboost Condition) - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 113896 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:16:21
             Freeze Frame:
                    RPM: 6340 /min
                    Load: 80.8 %
                    Speed: 171.0 km/h
                    Temperature: 76.0°C
                    Temperature: 22.0°C
                    Absolute Pres.: 1030.0 mbar
                    Voltage: 13.970 V
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 00210 558 45725
   VCID: 73E1BA7A121A4386965-8026
2 Faults Found:
00778 - Steering Angle Sensor (G85)
            003 - Mechanical Failure
01309 - Power Steering Control Module (J500)
            008 - Implausible Signal
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 6DD5AC02743E9576401-8038
3 Faults Found:
00756 - Left Vent Temp Sensor (G150)
            010 - Open or Short to Plus
01274 - Air Flow Flap Positioning Motor (V71)
            000 - -
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000005770127
   Coding: E58D0F270004151E001400001400000000087F075C
   Shop #: WSC 12345 785 00200
   VCID: 2B51621A8AAA5B461E5-807E
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 210108 021  0501
   Coding: 00038805
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     130506 014  1201
   Coding: 00208933
   Shop #: WSC 12345
7 Faults Found:
00061 - Footwell Lights
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 112938 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.10 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01504 - Bulb for License-Plate Light (X)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 112939 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.10 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01518 - Bulb for Back-Up Lights; Left (M16)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 223
                    Mileage: 113861 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.35 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01496 - Bulb for Fog-Lamps; Left (L22)
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 112938 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.10 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01500 - Bulb for Fog-Lamps; Right (L23)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 112938 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.10 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00978 - Lamp for Low Beam; Left (M29)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 112939 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.10 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00979 - Lamp for Low Beam; Right (M31)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 24
                    Reset counter: 199
                    Mileage: 112939 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.10 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0HM002
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D755C4264DEC5F6B01-8068
   Subsystem 1 - Serial number: 6332MSME2A062A337
   Subsystem 2 - Serial number: 6342MSME113B201D4
   Subsystem 3 - Serial number: 6352QSME0E271E05K
   Subsystem 4 - Serial number: 6362QSME0D5B4F3D%
5 Faults Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
            001 - Upper Limit Exceeded - MIL ON
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
01217 - Side Airbag Igniter; Driver Side (N199)
01221 - Crash Sensor Side Airbag; Driver Side (G179)
            008 - Implausible Signal - Intermittent - MIL ON
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 634 0070
   Coding: 0000012
   Shop #: WSC 01279 785 00200
   VCID: 76E7836E016856AEB1B-8023
1 Fault Found:
00883 - Ignition Switch (D) Terminal S
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K6 920 963     HW: 1K6 920 963
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0F4079991
   Coding: 0003403
   Shop #: WSC 65536 131 1104415
   VCID: EFE9360AFE32E766F2D-80BA
1 Fault Found:
00003 - Control Module
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 54857 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:53
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 310010651501F5
   Coding: 3D0F034007000001
   Shop #: WSC 05311 210 01865
   VCID: 2C5361068FA45C7E17F-8079
3 Faults Found:
00470 - Combination comfort Databus in Single Wire
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 112938 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:30:22
01305 - Databus for Infotainment
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 112938 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:30:22
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 139
                    Mileage: 112938 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:30:27
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1610
No fault code found.
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
   Component: Tuer-SG         006 1208
   Coding: 0000564
   VCID: 387B4D564BFCE0DE637-806D
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 69     2301
   Revision: 00H15000
   VCID: 2A5F671E8550424EE53-807F
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AJ
   Component:    KSG              0401
   Coding: 19C802487F2D8405485AC69010CC
   VCID: 78FB8D560B7C20DEA37-802D
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Part No: 1K0 951 178
   Component: Neigungssensor  001 0101
   Subsystem 3 - Part No: 1K0 951 178
   Component: Innenraumueberw.001 0101
2 Faults Found:
01134 - Alarm Horn (H12)
            011 - Open Circuit
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
   Component: Tuer-SG         004 0954
   Coding: 0000564
   VCID: 397D485270F6F9D69C9-806C
End   ---------------------------------------------------------------------
Offline doylebros
  • -Receive: 310
« Reply #5 on: March 15, 2014, 10:00:24 pm »
I would be charging the battery over night and rescanning as my starting point !
Offline xjay1337
  • -Receive: 377
« Reply #6 on: March 16, 2014, 01:25:07 am »
Clear all of the codes run the car for a day or two and see what codes come back.
Offline SI-R32
  • -Receive: 126
Re:
« Reply #7 on: March 16, 2014, 06:29:53 am »
I've tried clearing all the codes :-)
Offline biffobear
« Reply #8 on: March 16, 2014, 10:45:29 am »
Would get the battery checked or renewed maybe
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #9 on: March 16, 2014, 11:59:39 am »
check the battery is fully charged
Disconnect the battery and both terminals, then touch the the terminals together (not the battery, but red and black wires)
see what faults comes back
Cluster and Key coding
Location Great Yarmouth
