Author Topic: How low can I go?  (Read 2077 times)
Offline Gasman
How low can I go?
« on: March 15, 2014, 03:05:34 pm »
I'm not keen on my current stance and want to go a little bit lower especially on the rears.  I don't want it slammed but I would like there to bit little or no gap between the top of my tyres and arch.  I'm on 19"s however the arches were rolled by the previous owner I believe.   I'm not sure of the width and offsets of my wheels.  Would I get away with a 30mm drop all round?
Steel Grey GTI, 19" BBS RD383 wheels, R32 rear bumper, BCS R32 style cat back
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
Re: How low can I go?
« Reply #1 on: March 15, 2014, 03:07:36 pm »
You need to find the specs of your wheels first. Should be ok though
Offline Gasman
« Reply #2 on: March 15, 2014, 03:12:21 pm »
Ok mate ill whip em off and have a look at the markings.  This is the look I'd like..
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #3 on: March 15, 2014, 03:13:35 pm »
Then you will need coilovers  :wink:
Offline biffobear
« Reply #4 on: March 15, 2014, 03:49:45 pm »
I had to fit coilovers to get that stance. Plus had to remove adjusters on rear
Offline George10
« Reply #5 on: March 15, 2014, 07:59:02 pm »
As above^^ if I were you if roll your front archers to sit like that.
Offline DanMaytee
« Reply #6 on: March 15, 2014, 09:23:45 pm »
I'm on 19's (8.5j Et45 215/35 tyres) and mine fit perfect.  On the rear though I've cambered them to -2.5 degrees and added a 5mm spacer.  The fronts I haven't done anything to apart from the screw mod (http://www.golfmkv.com/forums/showthread.php?t=10909&highlight=fender+screw+mod).  I rub slightly on the arch liner if I corner hard but it's never caused any damage and I do like to hoon it around sometimes.  I'm guessing your wheels will be around a similar spec as mine so hopefully this will have helped.  If you whip a wheel off you might have stamped the ET on the barrel :).
Quick photo for reference (It's a Jetta but it's the same as a Golf)
Offline Gasman
« Reply #7 on: March 16, 2014, 06:22:41 pm »
Are you on 19's?
Offline Gasman
« Reply #8 on: March 16, 2014, 06:23:02 pm »
They've been rolled  :happy2:
Offline George10
« Reply #9 on: March 17, 2014, 10:30:31 am »
You should be fine then  :happy2:
