August 18, 2026, 07:17:31 am
All Things Mk5
Mk5 General Area
Rear Brake Pad Wear Indicator
Topic: Rear Brake Pad Wear Indicator (Read 6035 times)
zayd
Always Involved
-Given: 4
-Receive: 0
March 22, 2014, 02:37:37 pm »
As the title goes, does the MK5 Gti have a rear brake pad wear indicator. Its just that I've seen some Pagid pads on Euro Car Parts that are prepped for a wear indicator.
bacillus
Just look at my post count
-Given: 4
-Receive: 453
Re: Rear Brake Pad Wear Indicator
Reply #1 on:
March 22, 2014, 02:47:17 pm »
Quote from: zayd on March 22, 2014, 02:37:37 pm
No...
zayd
Always Involved
-Given: 4
-Receive: 0
Reply #2 on:
March 22, 2014, 02:49:51 pm »
So if they look worn down, they pretty much are then!
Better get some ordered from Euro's me thinks.
SI-R32
-Given: 8
-Receive: 126
Reply #3 on:
March 22, 2014, 02:52:45 pm »
think the wear indicator was included in the winter pack ?? just chop the wires off if you dont need them
zayd
Always Involved
-Given: 4
-Receive: 0
Reply #4 on:
March 22, 2014, 03:03:10 pm »
My car has the winter pack, but I think the previous owner just fitted some cheapo pads, which are TRW. I doubt they have the wear indicators.
SI-R32
-Given: 8
-Receive: 126
Reply #5 on:
March 22, 2014, 03:06:42 pm »
take wheel off or look through it on passenger side, if just behind the top of the disk there is a connector not being used then you have the ability to have a brake pad wear wire attached, if no connector it wasn't fitted
zayd
Always Involved
-Given: 4
-Receive: 0
Reply #6 on:
March 23, 2014, 07:16:01 am »
I'm gonna change the pads myself today using a caliper wind back tool. Do you need to leave the cap off the brake fluid reservoir when doing this procedure?
Beddie
-Given: 25
-Receive: 76
Reply #7 on:
March 23, 2014, 08:02:53 am »
Rear brake pad wear indicators have never been fitted to the mk5 regardless of whether it has the winter pack or not, front wear indicators only are standard on the mk5..
I've found that the rears will wind back fine both with the cap fitted and removed
Carbon Grey Edition 35 - Here
SI-R32
-Given: 8
-Receive: 126
Reply #8 on:
March 23, 2014, 08:07:33 am »
my mistake didn't even see he asked about rear......don't know how i just breezed over that!!
zayd
Always Involved
-Given: 4
-Receive: 0
Reply #9 on:
March 23, 2014, 09:06:25 am »
Thanks for the replies people.
zayd
Always Involved
-Given: 4
-Receive: 0
Reply #10 on:
March 23, 2014, 11:08:48 am »
Do I need to do anything special to my DSG shifter as I can't seem to get the caliper off.
Andy
Admin
-Given: 39
-Receive: 447
Reply #11 on:
March 23, 2014, 12:37:25 pm »
If there is a lip on the disc they can be a bit tight but leaver the caliper of
gttdi build thread
r32 build thread
zayd
Always Involved
-Given: 4
-Receive: 0
Reply #12 on:
March 23, 2014, 02:38:13 pm »
All done. This is the first time I've ever replaced brake pads and I'm quite pleased its all done now.
Just had to be careful as the handbrake needs to be released in order to free the rear brakes and I didn't want the car rolling off my drive!
The only issue I had is that, I ever so slight chipped one of my brake lines that go into the caliper and now I'm worried its gonna explode whilst I'm driving leaving me with no rear brakes.
All Things Mk5
Mk5 General Area
