August 31, 2026, 01:43:36 pm
All Things Mk5
How to Guides / Troubleshooting
Edition30 GTI Missfire :(
Pages:
3
Topic: Edition30 GTI Missfire :( (Read 12687 times)
GrayMK5GTI
Global Moderator
Just look at my post count
-Given: 125
-Receive: 248
Re: Edition30 GTI Missfire :(
Reply #30 on:
April 08, 2014, 12:39:08 pm »
And there is this stuff
http://injectedstore.com/products/injected-engineering-direct-injection-de-carbon-foam
Although its more expensive.
I'll try the Wynns one, any volunteers for this?
martziniuk
Won't Shut up.
-Given: 25
-Receive: 18
Reply #31 on:
April 08, 2014, 08:51:16 pm »
White spirit through the inlet temp sensor hole works a treat!
Mk2 Octavia vRS with K04 conversion, 3"TBE & Decat, APR HPFP, BDM Intake, S3 I/C, Sachs clutch & Unicorn custom map, S3 brakes, AP coilovers, THS mounts.
B8.5 Audi S4 with uprated pulley and unicorn Stage 2
gingerguild
Just Arrived
-Given: 3
-Receive: 1
Reply #32 on:
April 09, 2014, 11:51:35 am »
I appear to be having exactly the same issue as the OP. This thread has helped lots. Given me a few things to try :)
I took my car to MidlandVW who plugged it in with no misfire reported but it is certainly something you can feel at idle after the car has warmed up a bit, I'm pretty sure I'm not imagining it
GrayMK5GTI
Global Moderator
-Given: 125
-Receive: 248
Reply #33 on:
April 09, 2014, 02:26:31 pm »
It won't have logged a misfire fault code unless it's very serious. On VCDS you can use the misfire counter tool which logs soft misfires at idle you need a lot in a short period of time to throw up a fault code
edpower
Can't Read PM's Yet!
-Given: 0
-Receive: 0
Reply #34 on:
April 24, 2014, 06:51:37 pm »
Saintsteve
Reply #35 on:
April 24, 2014, 07:23:23 pm »
Quote from: edpower on April 24, 2014, 06:51:37 pm
Did you look at your live missfire count 1st??
edpower
-Given: 0
-Receive: 0
Reply #36 on:
April 25, 2014, 07:07:41 pm »
Quote from: Saintsteve on April 24, 2014, 07:23:23 pm
I have them on my polar fis, yes
Pages:
3
All Things Mk5
