Author Topic: How to change Fuel Pump Cam Follower on 2.0 TFSi  (Read 147213 times)
Offline StuF
  • -Given: 31
  • -Receive: 38
Re: How to change Fuel Pump Cam Follower on 2.0 TFSi
« Reply #90 on: November 06, 2014, 02:50:36 pm »
On advice I had my Cam Follower replaced - my Standard 08 GTI has covered 167000 miles and was still on the original one.
It showed minimal wear and was still good for 0000's more miles but was good to check and replace for piece of mind and the followers price!
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #91 on: November 06, 2014, 04:15:09 pm »
Tuned cars eat them A LOT quicker.
Even standard cars can get through them if the driver is a bit more throttle happy.  Perhaps that's testiment to your car being driven nicely @StuF
For the sake of £25 delivered: http://www.mk5golfgti.co.uk/forum/index.php?page=mods&mod=225
Offline StuF
  • -Given: 31
  • -Receive: 38
« Reply #92 on: November 06, 2014, 05:03:37 pm »
I think you are correct @Scottymon - the car appears to have been very very well looked after!
And for the sake of £25 it was worth changing - I imagine the car will be getting driven a little harder by me rather than the PO
Always better to be safe than sorry with these small items!  :drinking:
Offline KieranED30
  • Burning Rubber Since 16th Febuary 2012
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89941.0.html
« Reply #93 on: November 12, 2014, 06:51:26 pm »
The one I got of Ebay came today and its not greased up whats best to grease it up with and do I grease inside and outside??
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #94 on: November 12, 2014, 07:01:08 pm »
No need for grease. Just smear a bit of engine oil on and stick it in  :happy2:
Offline KieranED30
« Reply #95 on: November 13, 2014, 10:11:01 am »
Cheers, that's what I'll do & do I oil the Inside and outside or just ouside?
Offline edd30
« Reply #96 on: November 13, 2014, 10:50:29 am »
Inside and out. I dipped mine in engine oil. The 4 holes are for lubrication.
Offline KieranED30
« Reply #97 on: November 13, 2014, 10:58:49 am »
Nice one I'll be doing this when I finish work in a hour can't wait to see what mines like now I'll post a pic of I have time!
Offline edd30
« Reply #98 on: November 13, 2014, 11:13:50 am »
New follower on the right. Last image shows the camshaft lobe, you can see some marks, but can't feel them. Should be fine.
Not sure exactly how many miles the follower has done, but it could be original, as the gasket was black, the replacement gasket on the HPFP is light blue. I'll probably check it every other service. Car will get annual oil and filter changes, I do about 7k miles a year max.
Offline KieranED30
« Reply #99 on: November 13, 2014, 03:48:27 pm »
All done  :jumping: wind blew one of the t30 torque screws down the back of the engine took me 2 hours to find it with all sortes of tools grabber magnets and everything's or very annoyed even rang VW for a new one but they didn't stock them; I finally found it!
Took 20 mins if that if I take away the screw/bolt rinding grrrrr
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #100 on: November 13, 2014, 04:01:47 pm »
Such a PITA when things like that happen, well done for sticking with it... reminds me I need to check mine soon.
Offline KieranED30
« Reply #101 on: November 13, 2014, 04:07:17 pm »
I know I needed to car so couldn't stop till I found it I was on the verge of leaving it but I just couldn't! next time I will put them in the magnetic tray that's made to put loose bolts in that was sat about 3 meters away from me  :sad1: haha
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #102 on: November 14, 2014, 09:04:13 am »
I have one of these probably the most used tool in my garage.
Also bought one of these came in very handy recently when i lost a T30 bit.
05 | Tornado Red | DSG
Offline Eniqmatic
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,84578
« Reply #103 on: February 10, 2015, 04:19:23 pm »
Sorry for thread revival, but do you loose oil when doing this? Or can it be done without an oil change?
Thanks!
Offline edd30
« Reply #104 on: February 10, 2015, 04:47:37 pm »
No oil change needed. You loose a few drops.
