September 01, 2026, 05:34:38 am
All Things Mk5
Sat Nav and Car Audio
Stream music iPhone to RCD300
Topic: Stream music iPhone to RCD300 (Read 5992 times)
lennard_D
Always Involved
-Given: 6
-Receive: 0
May 12, 2014, 07:34:54 pm »
Hi guys
So I've spent loads of time researching various stereo upgrades. I originally started thinking about RNS510 but the main feature I wanted was to stream music from iPhone so with Bluetooth kit, plus Canbus gateway even used the upgrade was quite expensive. I then started thinking about used RCD510s and more recently thought about RCD310 but still need to spend dosh on canbus and Bluetooth.
I've now recently discovered that there may be a simpler and possibly cheaper fix. Can I just get a MDI connect for RCD300 then add a wireless adaptor? Anyone done this? Which parts would you recommend?
The main feature I want is music streaming. I'm not bothered about making calls when I'm driving. I also don't need a touch screen and happy to keep things simple. I would prefer better SQ but is there a massive difference between RCD300 and RCD510/310? I don't have particularly sophisticated ears!
Any thoughts welcome!
Len
LiamGTi
Always Involved
-Given: 1
-Receive: 4
Re: Stream music iPhone to RCD300
Reply #1 on:
May 12, 2014, 07:38:08 pm »
If you find out please let me know!
DamoP
Just look at my post count
-Given: 5
-Receive: 115
2007 Edition 30 number 1242
My Ride:
Reply #2 on:
May 12, 2014, 08:36:41 pm »
if it helps mate MDI's don't work on the earlier head units only RCD310/510 RNS310/510
MDI Armrest & Glovebox kits
Armrests, cloth and leather
lennard_D
Always Involved
-Given: 6
-Receive: 0
Reply #3 on:
May 13, 2014, 01:40:51 pm »
Thanks mate.
It doesn't look like my masterplan is going to work!
DamoP
-Given: 5
-Receive: 115
My Ride:
Reply #4 on:
May 13, 2014, 01:43:06 pm »
other options are vw iPod adaptor or AUX kits. If you need either i have both at the mo
lennard_D
Always Involved
-Given: 6
-Receive: 0
Reply #5 on:
May 13, 2014, 01:50:11 pm »
What is an IPOD adaptor? What functionality does that give you?
DamoP
-Given: 5
-Receive: 115
My Ride:
Reply #6 on:
May 13, 2014, 01:55:48 pm »
the iPod adaptor allows changing tracks ext. its the more basic system but works on the standard head units
lennard_D
Always Involved
-Given: 6
-Receive: 0
Reply #7 on:
May 13, 2014, 02:01:11 pm »
Can you connect wireless adaptor to allow Bluetooth streaming?
gazrn
Always Involved
-Given: 0
-Receive: 2
Reply #8 on:
May 13, 2014, 02:33:11 pm »
I tried to connect a bluetooth adaptor to the iPod connector in my armrest and it didn't work, it wouldn't even power it up let alone connect, ended up buying an old 2nd gen iPod nano and leaving it connected in the arm rest.
Last Edit: May 13, 2014, 04:17:44 pm by gazrn
GrayMK5GTI
Global Moderator
-Given: 125
-Receive: 248
Reply #9 on:
May 13, 2014, 04:05:54 pm »
Connects2 do a great interface for iPhone to RCD range. Have a look on eBay / google
Dang
Just Arrived
-Given: 0
-Receive: 0
Reply #10 on:
May 13, 2014, 05:32:25 pm »
I've connected a Bluetooth attachment to my iPod connection in the arm rest so I can stream my HTC one to it. The reason you didn't get power is because the old iPods are 12V which the connection in the armrest is set up as. Newer iPods or Bluetooth connectors are 5V. You can go on eBay and buy a 12v to 5v connector as they use different pins. All in all it cost me £12 to stream from my phone.
gazrn
Always Involved
-Given: 0
-Receive: 2
Reply #11 on:
May 13, 2014, 06:27:54 pm »
Ah right gotcha, cheers for the info gonna look into it now !!!
gazrn
Always Involved
-Given: 0
-Receive: 2
Reply #12 on:
May 13, 2014, 06:30:07 pm »
What bluetooth device do you use ?
Dang
Just Arrived
-Given: 0
-Receive: 0
Reply #13 on:
May 13, 2014, 06:43:54 pm »
http://www.ebay.co.uk/bhp/ipod-bluetooth-adapter
http://www.ebay.co.uk/itm/like/370843770662?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&device=m&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=108&ff19=0
Dang
Just Arrived
-Given: 0
-Receive: 0
Reply #14 on:
May 13, 2014, 06:44:56 pm »
This is pretty much what I've got. Obviously you can't change track through the steering wheel. I'm not that fussed and for the price you can't go wrong
All Things Mk5
