Author Topic: 370mm front discs  (Read 3392 times)
Offline DomBacon
370mm front discs
« on: May 12, 2014, 08:42:12 pm »
I know the audi rs3 discs dont fit mk5 golf gti's but what about the ttrs 370mm discs?
Anyone know if they would fit?
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
Re: 370mm front discs
« Reply #1 on: May 12, 2014, 09:02:05 pm »
Yes they fit straight on, you will need spacers also  :wink:
Silver is the way !
Offline DomBacon
« Reply #2 on: May 12, 2014, 09:09:39 pm »
Been offered a few sets but werent to sure
Also just been offered r8 brakes with s3 discs off a s3 but not sure if the brackets are the same
Offline Pikey Motorsports
« Reply #3 on: May 12, 2014, 10:25:00 pm »
Would need 19's though or not?
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline DomBacon
« Reply #4 on: May 12, 2014, 10:32:22 pm »
I haven't got a clue haha emailed a couple people and companies but no ones got back to me in a couple days
Offline Big Red T
« Reply #5 on: May 12, 2014, 10:36:34 pm »
18.s Are fine. Scopes is running these on his car .
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #6 on: May 13, 2014, 12:04:24 am »
I was running TTRS calipers with the 370mm ttrs discs, needed 10mm spacers to fit behind Huffs, but depending on what wheels you will be using a different size of spacer may be required.
Others have run with the 345mm discs from r32/s3's, but different brackets have been required to fit these, if you contact Daveb1970 here on the forum here, he will keep you right and also be able to supply you with the correct parts to fit.
He is a busy man, so hang in there !
Silver is the way !
Offline DomBacon
« Reply #7 on: May 13, 2014, 12:13:21 am »
Was thinking of r32 discs but someone has some 370mm ones as well, was looking into get some fifteen52 tarmacs or 3sdm 0.01s 8.5j wide so they should fit behind right without spacers?
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #8 on: May 13, 2014, 12:25:10 am »
I wouldn't be aware if they would fit behind your choice of wheel... Only one way to find out.
Buy the wheels, post them to me, I will trial fit them for you  :laugh:
Hopefully someone who has tried this combination out, can give a more suitable answer !
 :driver:
Anno the wheel weights need to be put to the back of the wheels, as they hit of the caliper, that's how close they are to the wheel, but if you used a smaller disc, like the r32 discs, this would be ok.
Hope that helps!
Silver is the way !
Offline dan930
  • -Receive: 56
« Reply #9 on: May 13, 2014, 12:59:50 am »
You can get the brackets to fit the ttrs/rs3 calipers with s3/r32 discs from Aks tuning
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline dan930
  • -Receive: 56
« Reply #10 on: May 13, 2014, 01:13:05 pm »
I've seen on audi forums that these 370mm discs are crap,warp easily etc etc
MK6 golfR dsg
AKS TUNED
R TECH custom map
Offline DomBacon
« Reply #11 on: May 13, 2014, 01:38:48 pm »
I've also heard that as well, might just order brembo discs and see what there like.
Offline dan930
  • -Receive: 56
« Reply #12 on: May 13, 2014, 02:24:19 pm »
DaveB even commented that the disc are like chocolate...
MK6 golfR dsg
AKS TUNED
R TECH custom map
Offline DomBacon
« Reply #13 on: May 13, 2014, 06:14:13 pm »
Cant find a decent set anywhere with r32/s3 discs :(
