All Things Mk5 > Performance Modifications
Golf 5 GTi K04 upgrade help needed
AxeMan:
So K04 plus manifold, S3 oil feed pipe for turbo, S3 dv relocation kit and software?
Is there anything else I'll need so long just to make it run? Any other pipes/brackects etc etc? Dont want to go get the above mentioned and tgenfind out tthat this doesn't work or I'll still need that. Want to get everything one time so I cam get it running atleast..
martziniuk:
You don't need any oil lines, the K04 turbo uses the K03 lines. Get new crush washers for the oil and water connections.
AxeMan:
Can anyone please give me the part numbrs for the relocation kit?
I got the wiring harness worked out already. Its just the other patts I need that I'm not sure of as I can't find a direct answer for the part numbers..
I saw on another fourm that I need a noise pipe? I googled it and it doesn't look like my car has that on it.. is this nessasary?
And also a S3 intake pipe as I'm running my stock airfilter box?
And also the S3 pressure pipe?
Thank you guys so very very very
All the help and advice is greatly appreciated
bacillus:
These are what's needed for a full build.
danishmkvgti:
--- Quote from: AxeMan on May 15, 2014, 11:14:54 pm ---Can anyone please give me the part numbrs for the relocation kit?
Noise pipe is for the LHD cars :)
--- End quote ---
Navigation
[0] Message Index
[*] Previous page
Go to full version
