Author Topic: Side Mirrors - HELP  (Read 1029 times)
Offline mvb12
  • -Receive: 64
Side Mirrors - HELP
« on: June 16, 2014, 02:21:23 pm »
Hi All,
Right, got a wee problem, i changed my steering wheel over to the mk6 wheel and since then my side mirrors have a mind of there own.
when I swapped the wheels over the mirrors kept moving by themselves. this has now resolved itself, but now the issue is the control switch.
When I adjust the right mirror, both mirrors move, but when i adjust the left it works as it should and only the left moves.
Anyone able to shed some light?
Offline Dave7692
Re: Side Mirrors - HELP
« Reply #1 on: June 16, 2014, 02:46:12 pm »
My golf has had the same issue since I bought it and as far as I know it hasn't had the wheel replaced.
Offline doylebros
  • -Receive: 310
« Reply #2 on: June 16, 2014, 07:41:56 pm »
It's a coding issues.
If you've got a high-line cluster it's a simple tick box if not it's VCDS To recode.
Offline mvb12
  • -Receive: 64
« Reply #3 on: June 16, 2014, 07:45:09 pm »
Tick box where in the highline.
If using VCDS what should the coding be?
Offline doylebros
  • -Receive: 310
Offline Sie
« Reply #5 on: June 16, 2014, 08:22:59 pm »
Both moving together is actually a feature helps you get the left hand one close apparently. My 05 golf has done it since I had it.
Simon
Fettled Laser Blue '05 GTi 5dr
Offline mvb12
  • -Receive: 64
« Reply #6 on: June 16, 2014, 08:34:03 pm »
There didn't move together but in any direction.
Sorted it with VCDS now. Cheers guys.  :happy2:
