Author Topic: BSH Stage 1  (Read 3632 times)
Offline edition_30
BSH Stage 1
« on: October 26, 2009, 08:39:09 am »
I notice with the stage 1 fix that the blanking plate simply blocks off all exit ports on the block.. i take it then the oil is forced back into the system..
1st is this good for the car?
2nd if its a viable fix how come the car never came like this from factory?
Offline edition_30
Re: BSH Stage 1
« Reply #1 on: October 26, 2009, 09:54:24 pm »
Any thoughts guys?
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
Re: BSH Stage 1
« Reply #2 on: October 26, 2009, 09:57:05 pm »
maybe my earlier post can give you a better idea how the system works?
http://www.mk5golfgti.co.uk/forum/index.php?topic=8565.msg132531#msg132531
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
Re: BSH Stage 1
« Reply #3 on: October 26, 2009, 10:36:26 pm »
It doesnt block off all ports (not on the block though). It simply takes the PCV out the equation, routing the oil destined for it back into the top of the head. There is still a vent for the oil that is routed back to the sump.  :happy2:
#1493
Re: BSH Stage 1
« Reply #4 on: October 27, 2009, 10:49:41 am »
....Broadly speaking, the oem method is a way to satisfy regulations which the car manufacturer (VW/VAG) is subjected to regarding emissions.
To me it seems like a clear case of screw the potential harm to the longevity of the engine components, a minutely tiny reduction of emissions will help our rating and sell more cars etc etc.
AFAIK, if you fit a race catch can which vents to the atmosphere, your car will fail MOT.
Offline edition_30
Re: BSH Stage 1
« Reply #5 on: October 27, 2009, 02:42:58 pm »
Thanks for the reply mate.. but by routing this oil back into the head, will it cause any damage etc... otherwise why would vw use this kind of method & not just create a system which removes the pcv..
Just trying to get my head round it
Re: BSH Stage 1
« Reply #6 on: October 27, 2009, 02:51:49 pm »
just a quick thought, if this a fault with the engine then i don't want to sound daft but is there any data in the uk saying there is a problem with the engine and if so vw uk need to made aware of this and all cars with this engine need to have this sorted under warranty as its an engine design with a fault  :confused:
Offline bacillus
  • -Receive: 453
Re: BSH Stage 1
« Reply #7 on: October 27, 2009, 03:23:26 pm »
The bean counters at VW most likely know that by the time most owners start having big issues with the valve build up problem, the car should be out of warranty.
Re: BSH Stage 1
« Reply #8 on: October 27, 2009, 03:31:59 pm »
warranty or not i know mitsubishi who i worked for there was a problem with some bottom arms and every car that came in no matter how old had them replaced free of charge as it was a defect in the design
Offline Phil@BSH
Re: BSH Stage 1
« Reply #9 on: October 30, 2009, 05:15:34 pm »
Hello, take a look at this posting in the help and trouble shooting forum. I made a detail post explaining the different systems we offer as well as some more detailed look into the factory design. Please feel free to email us if you have any questions.
http://www.mk5golfgti.co.uk/forum/index.php?topic=8565.0
Edit: Noticed I actually replied to you in that thread!  :happy2:
513 bhp at 24 psi. More still to come!
BSH Speedshop
info@bshspeedshop.com
Help us work with you. If we make a part that you want and it needs special Euro fitments please contact tech@bshspeedshop.com
