Author Topic: Rs3 brakes  (Read 2351 times)
Offline MJGib
  • -Given: 22
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,85702
Rs3 brakes
« on: July 08, 2014, 03:15:51 pm »
Do RS3 brakes fit straight onto mk5 golf gti?
MK5 Golf GTI: K04 converted stage 2+ (I don't own this car no more)
Insta - gibs94_
Offline TommyR
  • -Receive: 20
  • Black Edition 30
Re: Rs3 brakes
« Reply #1 on: July 08, 2014, 03:35:28 pm »
Discs won't but the calipers will :happy2:
Offline MJGib
  • -Given: 22
Re: Rs3 brakes
« Reply #2 on: July 08, 2014, 03:37:49 pm »
What discs would I use?
Insta - gibs94_
Offline TommyR
  • -Receive: 20
  • Black Edition 30
Re: Rs3 brakes
« Reply #3 on: July 08, 2014, 03:41:22 pm »
3 main options...
  • Use the TTRS disc as the RS3 won’t fit easily due to a different offset. However from what I have read both discs are expensive to replace and widely considered pretty pants!
  • Buy a DaveB fitting kit to allow you to run the TTRS/RS3/Aston 4 Pot caliper on a 340/345mm disc as I have done.
  • Finally the ultimate option a floating rotor setup… If I remember correctly DaveB sells a 362mm kit and Alex sells a 370mm kit
Offline MJGib
  • -Given: 22
Re: Rs3 brakes
« Reply #4 on: July 08, 2014, 03:42:38 pm »
3 main options...
Insta - gibs94_
Offline Mandy
  • -Given: 95
  • -Receive: 94
Re: Rs3 brakes
« Reply #6 on: July 08, 2014, 03:49:46 pm »
I wouldn't recommend TTRS discs as I think they are meant to warp real easy. Best thing to do is buy the fitting kit from DaveB or AKS Alex so you can run the 340mm TTS discs. :happy2:
