Author Topic: ABS pump  (Read 4750 times)
Offline wodder42
ABS pump
« on: July 13, 2014, 06:45:17 pm »
Hi all
had a disaster this week.  After cganging the steering wheel the power steering light camr on and would go off.  So went to get it rrset at the local independent vw garage...and then the power steering went and wouldnt come back....well vagcom camt help, the techs dont know whats wrong so they advised getting new abs pump...that has half helped.  The steering angle sensor still isnt picking up movement of tje steering wheel and wobt talk to the abs pump.  Cars been laid up at the workshop now for 10 days...any ideas anyone?
140 GT, Steel grey, smoothed R32 rear, GTI front with all black US grill, DRL's, ED30 interior, GTI pedal set, 18" Monzas, GTI headlights and R32 rear lights
Offline wodder42
Re: ABS pump
« Reply #1 on: July 13, 2014, 09:31:26 pm »
They tried a new steering angle sensor before the pump...didnt help so put old one back...maybe try a new one again now it has a new pump?
Im afraid I don't know what the vagcom codes are...as it in at the garage...its got VW stumped. :scared:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
Re: ABS pump
« Reply #2 on: July 13, 2014, 09:54:34 pm »
God, feel for you mate.
Did they follow the procedure:
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_%281J%29_Brake_Electronics_%28MK60%29#Basic_Setting
I have the G85 issue and am going to run that procedure before installing a new SW sensor.
No damage to the loom or such like? Plenty of battery power? Have they driven the car?
I'm sure someone else on here will have a better knowledge of these things... hope you get it sorted, keep us updated. :happy2:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Re: ABS pump
« Reply #3 on: July 13, 2014, 09:55:33 pm »
Just seen this mate:
http://www.mk5golfgti.co.uk/forum/index.php?action=printpage;topic=41670.0
Talks about corrosion in the connectors, might be worth suggesting to them. :happy2:
Offline wodder42
Re: ABS pump
« Reply #4 on: July 14, 2014, 07:05:29 pm »
Not heard from them today...prob not even touched the car...just want it fixed now!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: ABS pump
« Reply #5 on: July 15, 2014, 10:53:05 am »
sounds like they don't know what they are doing
where are you located
Cluster and Key coding
Location Great Yarmouth
Offline wodder42
Re: ABS pump
« Reply #6 on: July 15, 2014, 07:10:41 pm »
Im in thornton cleveleys near blackpool...its a specialist vw garage doing the work...so you would hope they knew what they were doing...still not done.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: ABS pump
« Reply #7 on: July 15, 2014, 11:14:34 pm »
new ABS pump after changing steering wheel... sounds daft to me
Offline wodder42
Re: ABS pump
« Reply #8 on: July 16, 2014, 06:43:38 pm »
I agree...but seen the vagcom...the steering angle sensor isnt picking up movement.  From what I have been told, the steering initialization process goes through to the last instruction then wont do it...hence no power steering.
Offline doylebros
  • -Receive: 310
Re: ABS pump
« Reply #9 on: July 16, 2014, 07:06:32 pm »
Noticed this in another post and would check with your repair if he's looked at this as the source of your problem?
Make sure your VCDS is not set to 00000. If it is, change to something like 12345 then;
Plug in VCDS.
Drive below 20 kph in a straight line for a short distance.
Then, whilst driving, turn the steering one turn to the right and one turn to the left.
Straighten the steering wheel and stop. Keep engine running.
Do not touch the steering wheel.
Using VCDS,
Select 03 Brake electronics.
Security access 16
Enter 40168 to enable basic settings.
Click “Do it”
Select Basic settings 04
Group 060
Click “Go”
Activate the basic setting
Click ON/OFF/NEXT
If successful, Field 2 will say “OK”.
Click “Done”, “Go back”
This means the controller has learned the zero/straight ahead position.
To check it has worked go to Measuring block 08.
Group 004
Click “Go”
Field 1 value must be between -1.5° and + 1.5°
The car should now be good to go.
Offline wodder42
Re: ABS pump
« Reply #10 on: July 17, 2014, 06:41:21 pm »
Got my car back today.  All fixed.  Took 2 weeks mind!  The ABS pump had 3 very corroded and pitted rings and the base of the connectors  and there was some dodgy wiring behind the dash...hence the systems couldnt communicate...all in all an expensive time...just over a grand  :confused:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
Re: ABS pump
« Reply #11 on: July 17, 2014, 06:44:37 pm »
It was the connectors then! And f*ck that for a price :sad1:
