Author Topic: rvc screen not working.  (Read 4315 times)
Offline Kev
« on: July 27, 2014, 07:44:34 pm »
Hi ladys and gents I have retro fitted an rvc into my 2007 golf gti the camera pops out as it should but with no change to the rns screen,  when I go into the setup menu it is recognising the camera operating,  hope some one can shed some light on my issue.
« Last Edit: July 27, 2014, 07:46:08 pm by Kev »
Offline doylebros
  • -Receive: 310
Re: rvc screen not working.
« Reply #1 on: July 27, 2014, 07:59:52 pm »
This if I remember correctly this was the advice I was given:-
Programming Head Unit RNS 510
Using Vagcom/VCDS the headunit requires programming to tell it of the existence of a RVC.
Connect to controller 37 and in long coding under Byte 3 select Bit 6.
To complete the programming reboot the RNS 510. - press the left arrow button, right arrow button, and the star button all at the same time, and the RNS will reset and accept the changes.
Offline Kev
« Reply #2 on: July 27, 2014, 08:10:43 pm »
Ive tryed that mate and still nothing.
Offline doylebros
  • -Receive: 310
« Reply #3 on: July 27, 2014, 08:24:34 pm »
Assuming the equipment is new or if second hand you bought it from a good source?
My first move would be rechecking the coaxial cable to the rear of the head unit and the boot connections as there's not a lot after that since the camera is popping out and you've coded it.
Offline Kev
« Reply #4 on: July 27, 2014, 09:11:28 pm »
Hi yeah ive checked the lead at both ends only thing I get is when I go into setup and it says rvc on and off when putting it into reverse.
Offline doylebros
  • -Receive: 310
« Reply #5 on: July 27, 2014, 09:18:25 pm »
Sorry can't help you as I've never had no faults with the system and my install was trouble free.
May be Eddie-NL or Golfman may read this and offer some guidance!
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #6 on: July 27, 2014, 11:40:13 pm »
Is the camera actually getting power? I have the one in the bumper and that was my problem when i was fitting it
Offline Kev
« Reply #7 on: July 29, 2014, 03:43:17 pm »
Hi yeah ive checked all the wiring at tailgait end and behined the rns and also the permenant live to the fuse box, when I go into the secret menu it says rvc on and off when putting in and out of reverse.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re:
« Reply #8 on: July 29, 2014, 04:35:29 pm »
Have you tried unticking the box with vcds, reboot the rns, tick again and restart the rns again and then try?
Offline Kev
« Reply #9 on: July 29, 2014, 09:28:15 pm »
Yeah ive tryed that too, I have noticed tnight it only operates the central locking on the tailgait with the ignition on if I try unlock the car and try open the boot it stays locked unless the ignition is on, hope this sheds a tad of light on it.
Offline Kev
« Reply #10 on: July 30, 2014, 08:06:32 pm »
Can anyone help.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #11 on: July 30, 2014, 10:20:42 pm »
Is the boot central locking a new thing thats happened since you coded it?
Offline Kev
« Reply #12 on: July 31, 2014, 07:26:06 am »
Ill be honest im not sure as I go into my boot once a blue moon.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #13 on: July 31, 2014, 10:08:04 pm »
I wonder if it is a coding / power issue. Get some in the boot to mess with the wiring whilst you hold it in reverse. Random question but have you got a reverse bulb in too? My plays up when the bulb is out. It works for a bit then turns off.
Offline Kev
« Reply #14 on: August 01, 2014, 10:52:25 am »
Thanks mate ill check my reverse light ive checked the coding as ed supplied that for me it cost me a lot so really need to sort it, I solded all the wiring in still carnt understand why it only works with the ignition on as it works off a permenant live.
