October 09, 2026, 03:47:36 am
All Things Mk5
Cosmetic/Interior Modifications
central interior bulb
Topic: central interior bulb (Read 2798 times)
Andy
Admin
Just look at my post count
-Given: 39
-Receive: 447
August 08, 2014, 11:45:24 pm »
only realised it had this when i was putting led bulbs in the little map lights this light or i havent noticed it hasn;t worked--put new bulb in but still doesn't work--not sure if its the light holder or what the problem is
gttdi build thread
r32 build thread
Andy
Admin
-Given: 39
-Receive: 447
Re: central interior bulb
Reply #1 on:
August 09, 2014, 08:21:25 pm »
gttdi build thread
r32 build thread
HandyAndy
Always Involved
-Given: 6
-Receive: 3
MkV Golf GTs 140
Reply #2 on:
August 09, 2014, 08:48:27 pm »
Can you put a voltage meter on to see if there is any power to the contacts? If not you could trace the feed back to the fuse to see that its not blown?
United grey - Mk5 GTs [140] TDI on a 08 reg.
Andy
Admin
-Given: 39
-Receive: 447
Reply #3 on:
August 09, 2014, 09:15:26 pm »
the 2 map lights either side work so there must be power getting upto it
gttdi build thread
r32 build thread
JaseGti
Always Involved
-Given: 3
-Receive: 9
Reply #4 on:
August 10, 2014, 12:06:37 am »
Sounds silly but you could try turning the bulb 180 and putting it back in.
Worked for me when installing mine
CW is the way forwards
Remoteclothing.com
HandyAndy
Always Involved
-Given: 6
-Receive: 3
MkV Golf GTs 140
Reply #5 on:
August 10, 2014, 10:14:13 pm »
Is the light controlled by the door switch as the door opens? Could it be the switch is not making contact and opening the circuit?
Andy
Admin
-Given: 39
-Receive: 447
Reply #6 on:
August 10, 2014, 10:54:13 pm »
Well got it sorted it was a bad connection
gttdi build thread
r32 build thread
HandyAndy
Always Involved
-Given: 6
-Receive: 3
MkV Golf GTs 140
Reply #7 on:
August 14, 2014, 09:57:28 pm »
Quote from: maxitrol on August 10, 2014, 10:54:13 pm
After reading this reply I had to check as my light was not working either? I took the cover lens off and found in the front of the car and found no bulb, just the two map light spots. Then the penny dropped, you were on about the rear set of lights
Andy
Admin
-Given: 39
-Receive: 447
Reply #8 on:
August 14, 2014, 10:11:07 pm »
No the front ones as the early mk5 had 3 lights on the front
gttdi build thread
r32 build thread
Andy
Admin
-Given: 39
-Receive: 447
Reply #9 on:
August 25, 2014, 11:23:18 pm »
Got the centre bulb working just a bulb blown
gttdi build thread
r32 build thread
All Things Mk5
