June 18, 2026, 03:01:31 am
All Things Mk5
Sat Nav and Car Audio
RNS 510 switches to SD card on it's own??
Topic: RNS 510 switches to SD card on it's own?? (Read 1472 times)
Spankiee
Always Involved
-Given: 0
-Receive: 20
August 14, 2014, 09:58:32 am »
When I have the radio on the Rns 510 switches to SD card in it's own sometimes??
Anyone had this problem before?
Also why does it never seem to go loud enough. I can have it at full
Volume and I can still talk to my passengers pretty easily. I've messed about with loads of settings and it doesn't make much difference and also reset to factory settings. :(
I'm sure the original RCD 500 was way louder
candy white edition 30
SI-R32
Just look at my post count
-Given: 8
-Receive: 126
Re: RNS 510 switches to SD card on it's own??
Reply #1 on:
August 14, 2014, 10:03:19 am »
i'll put money on it that the RNS you've got was out of a car that had factory fitted amp and the settings were not changed via VCDS before you bought it, thats why its not loud
RetroRaz
-Given: 32
-Receive: 194
Reply #2 on:
August 14, 2014, 10:08:25 am »
try another SD card.
#RetroRaz -
https://instagram.com/retroraz/
Spankiee
Always Involved
-Given: 0
-Receive: 20
Reply #3 on:
August 14, 2014, 11:36:31 am »
Si r32 thanks for that I'll look into it :)
Ok I'll try another SD card but not sure if that will make a difference.
SI-R32
-Given: 8
-Receive: 126
Reply #4 on:
August 14, 2014, 11:50:52 am »
you need to make sure that you have
no sound system installed
active speakers installed (or some thing like this)
and one more which i forget
paulw123
Won't Shut up.
-Given: 80
-Receive: 47
Reply #5 on:
August 14, 2014, 01:29:45 pm »
the SD card takes the unit over anytime by inserting it, so maybe you have dirty card contacts? and when they make/break the unit thinks you have just inserted new card.
try another good clean card maybe....
Spankiee
Always Involved
-Given: 0
-Receive: 20
Reply #6 on:
August 14, 2014, 10:22:55 pm »
Cheers boys
All Things Mk5
