Author Topic: Mk7 steering wheel into mk5 gti  (Read 190964 times)
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #15 on: September 13, 2015, 04:53:25 pm »
Hi
Fitted R20 steering wheel into my MK6 (with the same 1K0.. CH steering module as MK5) and all buttons work but they wont illuminate. Yet.
To get your buttons illuminate on MK5 you will need to swap the steering module from newer model 2010up. To make it easier I made myself wiring adapter so I can always remove it and put original module back.
I test fitted it in my car and on ady-uk 2005 MK5. All works as it should, buttons, illumination etc.
Also tested 3 or 4 MK7 and Rocco wheels with cruise buttons and non of them works with 1K0 or 5K0 modules. Only the one without cruise buttons works.
Alex
« Last Edit: September 14, 2015, 11:03:02 pm by olsen-72 »
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline DANBOY66
  • -Given: 41
Re: Mk7 steering wheel into mk5 gti
« Reply #16 on: September 14, 2015, 10:02:13 am »
thanks for the replys lads
the only other question is the dsg padels i take it they work as well mk7 wheel on a mk5  :wink:
Dan..
Offline patpong_pete
« Reply #17 on: September 14, 2015, 05:22:57 pm »
mk7 Wheel
is it me or does it look massive ?
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #18 on: September 22, 2015, 12:38:57 pm »
Hi @olsen-72 this is Luke from ReddiWraps.  :happy2:
I've just ordered a Mk7 GTI red stitch steering wheel without cruise. Can you retrofit this for me with illumination?
#1493
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #19 on: September 22, 2015, 12:40:26 pm »
Inbox me ur mobile mate plz.
Offline DANBOY66
  • -Given: 41
« Reply #20 on: September 22, 2015, 12:56:20 pm »
do you have a part number for that steering wheel ?
Dan..
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #21 on: September 22, 2015, 02:14:40 pm »
#1493
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #22 on: September 28, 2015, 12:30:47 pm »
So it transpires that illumination will actually never work, I need the CH controller (but knew that would probably be required) and also I need a modified loom to make the horn work.
#1493
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #23 on: September 29, 2015, 08:32:49 am »
I have a Mk5 Golf 4Motion and Alex spent an afternoon testing his Mk7 wheel in my car
All buttons and illumination worked.
I have seen it working in my car.
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline MK1Campaign
« Reply #24 on: September 29, 2015, 09:57:48 am »
How do you stand with airbag deployment on mods like this with the wheel being from another MK?
Surely injury is possible if the wheels at a different position.
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #25 on: October 02, 2015, 09:28:52 pm »
This is now all working (due to me missing the MFSW wiring completely thanks @olsen-72 ).
I replaced the controller with the CH version, nav etc all coded up. Needed to do some basic settings on the steering and abs systems. But no error codes now.
Illumination still doesn't work unfortunately. If anyone else comes up with a solution, it would be great to find out.
#1493
Cam6353
« Reply #26 on: October 10, 2015, 09:20:15 pm »
Hi there,
Looking to put a mk7 wheel in my mk5, I have the highline display which requires the steering wheel buttons to work to operate it, does anyone know how much modification to the loom is needed to make the buttons work and the horn.
Also is the airbag plug the same?
cheers in advance
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #27 on: October 12, 2015, 05:20:45 am »
No loom modification required. Make sure your new steering wheel and airbag come with the correct loom. Just need a CH controller coding correctly.
#1493
roshan2529
« Reply #28 on: November 09, 2015, 04:11:27 pm »
Hi
I am too facing the same issue when trying to fit mk7 gli steering wheel on a mk5 jetta 2010..
- some buttons work but do not light up
- and horn not working.
i have also installed a ch controller after instructed by the seller of steering.
what kind of a wiring change is required?? do i need a different controller? or slipring.
Pls help.
Thanks,
Roshan
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #29 on: November 10, 2015, 04:57:25 pm »
No wiring changes were needed to get the horn working.
Illumination is impossible without a Mk6 steering rack.
I'll probably look at swapping mine at some stage with someone that has a Mk6 Edition 35, as they can get the illumination working.
#1493
