Author Topic: Boost PCV Valve part code  (Read 7511 times)
Offline irish_ram
  • -Given: 200
« on: August 23, 2014, 10:31:07 am »
Does anyone know what part number I need to replace the above on a MK5 1.4 TSI.
I have searched and cannot find the part so checking on here before I go and take it out of car to check the part code.
Offline irish_ram
  • -Given: 200
Re: Boost PCV Valve part code
« Reply #1 on: August 25, 2014, 04:27:26 pm »
Anyone able to help on this. Also not sure if I am being stupid but took the engine cover off and could not see the PCV valve in the location most people say it is. Is it in a different location on the 1.4 TSI
Offline doylebros
  • -Receive: 310
Offline irish_ram
  • -Given: 200
« Reply #3 on: August 25, 2014, 05:34:52 pm »
It's not the same for the 1.4 FSI engine
This should be your layout
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=1&grf=010378474&bf=10378&hgug=103&ug=03&parent_id=2335018
I presume you meant TSI :) but I cannot see the PCV location on that diagram or am I being stupid
Offline doylebros
  • -Receive: 310
« Reply #4 on: August 25, 2014, 06:11:34 pm »
Slip up there on my behalf - what Engine model code is your engine.
Offline irish_ram
  • -Given: 200
« Reply #5 on: August 25, 2014, 06:20:32 pm »
It is a 1.4 TSI 170 version but not sure on the Engine Code
Offline irish_ram
  • -Given: 200
« Reply #6 on: August 25, 2014, 06:25:48 pm »
The sticker in the boot has BLG if that is any help
Offline doylebros
  • -Receive: 310
« Reply #7 on: August 25, 2014, 06:50:02 pm »
This is your set up different - this is what I assume your getting at?
Look at item 8 - 03C 103 474 J  - £53.90 - vent hose
Offline irish_ram
  • -Given: 200
« Reply #8 on: August 25, 2014, 06:59:01 pm »
Cheers,
However I have been searching on the VCDS error I am getting and reading an official manual it is saying it could be one or both of the below causing my error
Turbocharger air recirculation valve N249 or Charge pressure control solenoid valve N75
Offline doylebros
  • -Receive: 310
« Reply #9 on: August 25, 2014, 07:06:20 pm »
Cheers,
Look here for N249 valve item 31 03C 906 283 - £48.62 full retail inc vat
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=1&grf=013315474&bf=13315&hgug=133&ug=33&parent_id=2339074
N75 is for the BKD Eng
Offline irish_ram
  • -Given: 200
« Reply #10 on: August 25, 2014, 07:21:00 pm »
Cheers,
Nice one, will get one of these and see how easy it is to fit  :happy2:
Offline doylebros
  • -Receive: 310
« Reply #11 on: August 25, 2014, 07:35:08 pm »
Never done one on your model but I can't see it being difficult.
