Author Topic: Jay's Golf Coupe "racek0r" project  (Read 221908 times)
Offline th3_f15t
  • -Receive: 183
Re: Jay's "Like a golf but not a golf"
« Reply #60 on: November 17, 2014, 04:25:39 pm »
Just remember that every time you stamp on those lovely brakes of yours :P. Be interested to see how the EBC discs fair up too, I've not read great things about pads but not a lot on discs. And if Mr. AKS says they're good enough...
« Reply #61 on: November 17, 2014, 04:27:20 pm »
To be honest I'm not looking forward to replacing the pads ... the Pagid RS4-2 are around £250 for a set of fronts....  :sick:
I imagine that they are 200-250 for the porsche 4 pots too.
You could havr gone OEM TTRS pads to save money.
Offline th3_f15t
  • -Receive: 183
« Reply #62 on: November 17, 2014, 04:33:23 pm »
see, I'm looking at just OEM pads for the Porsche brakes in fairness. Would consider some track alternatives for track days and summer use when the roads are drier and I'll push it more, swapping to standard pads in winter time (probably overkill). Also, as I mentioned, it's the use of spacers that concern me as I'm not a fan of them, don't know why I just don't like them.
Offline xjay1337
  • -Receive: 377
« Reply #63 on: November 17, 2014, 05:10:24 pm »
I could have but if you put good brakes why skimp with pads... Will see how they last, see if there's another option out there.  :smiley:
Offline vRSAlex
  • -Receive: 253
« Reply #64 on: November 17, 2014, 06:52:45 pm »
You could have gone OEM TTRS pads to save money.
At £300 a set  :P
Follow AKS tuning on Facebook
« Reply #65 on: November 17, 2014, 06:53:40 pm »
Your kidding? Really?  :signLOL: :signLOL: :signLOL:
So RS4-2 pads cheaper than OEM
Offline Biano44
  • The CC GT 200
« Reply #66 on: November 17, 2014, 08:06:49 pm »
I'm fairly sure that Alex can supply Pagid pads for around £100. In fact I'm considering changing to them as these RS4-2's are doing my box in!
Offline Biano44
  • The CC GT 200
« Reply #67 on: November 17, 2014, 08:09:21 pm »
I'm sure when I bought my DS2500's Dave charged me about £130.......but the dust that comes off them is a bitch to get off your wheels.
« Reply #68 on: November 17, 2014, 08:19:02 pm »
I think its the plain discs... they dont clean the pad surface well enough. Mine are pretty much OEM quiet
Offline xjay1337
  • -Receive: 377
« Reply #69 on: November 17, 2014, 08:35:27 pm »
Notice a very very faint ticking braking from low speeds but it's only intermittent.  No noise on mine really. If you didnt know the car you would just think they were normal brakes! (From the sound...)
Offline xjay1337
  • -Receive: 377
« Reply #70 on: November 23, 2014, 12:36:10 am »
Stayed up till about 3am cleaning the car...needed the therapy lol...
IMG_0542-2 by Fat Bear Photography, on Flickr
Certainly had been putting these Pagid RS4-2 Blue's through their paces..
IMG_0537-1 by Fat Bear Photography, on Flickr
IMG_0539-1 by Fat Bear Photography, on Flickr
Then took my old man to get his new car, a CR170 Octavia VRS - Cool to have my Dad in the same sort of car as mine, already got him primed to pull the trigger on some H&R springs, ball joints and bushes courtesy of Alex
IMG_0557-1 by Fat Bear Photography, on Flickr
Then the next day I set off for Darkside at stupid-o-clock
Arriving on literally no sleep and 3 red bulls... I grab a half-arsed shot of her on the dyno.
IMG_0590-1 by Fat Bear Photography, on Flickr
At Darkside we had the following:
EGR Delete
3 Inch Downpipe / DPF/Cat removal
Hard cut limiter set at 5k
It was down on power compared (normally from my experience VAG engines pull about spot on or just over their rated power) but the end figure is there or there abouts.
I spent a lot of time talking to Darkside and perusing other diesel tuning forums to get a proper idea of what sort of power these engines reach as there's not much in the way of actual dyno'd & verifiable output. Darkside said anything between 195 and 205 is bang on the money.
My Fiscon has also highlighted how quickly the intake temps can rise, even when it's 8 or 9 degrees outside the temps shoot up from about 11-12 degrees to 22 or 23 after a single pull through 3rd and 4th, so an uprated intercooler is on the cards - watch this space...
Regarding the future power, my EGR was apparently very blocked up and they were surprised it hadn't caused me any issues - because of this they recommend that I clear the inlets and remove the swirl flaps which may free up a bit of extra power.
A 2056 and tubular manifold is on the cards but having just spunked £3k on the car in the matter of 2 weeks I need to let my bank account balance settle (and sell my Golf FFS) - I think 240-250bhp and this would be a beast of a car on road and track. For now it's quick enough to put a smile on my face and handles brilliantly.
Driving wise, well the tuning has transformed it - It no longer feels breathless and does pull very well indeed. I would say it's quicker than my GTI was standard. The MPG has also improved quite a bit. Ryan was very complimentary on the handling setup saying it's one of the nicest cars they've driven and how well it handles and rides.
The next plans are pop back over to Alex for my cat-back exhaust section to be made up, giving me a full 3 inch TBE, we will see what he can do RE the swirl flaps as well which is happening on the 19th of December. Gonna tweak my short shift (change some bushes and add some washes to stiffen up the side to side movement) and look into a bit of fabrication for a heat shield or two...
And here's the results.
10376188_380320572136615_3506914564937856865_n by Fat Bear Photography, on Flickr
So went from 161 to 194bhp with a huge jump in torque from 270 to 330lb ft
Am I happy with the figures? No, if I'm honest. Then again I have always been a subscriber to the "under the graph" dyno area, which has improved MASSIVELY everywhere along the rev range - But I take some comfort knowing that Darkside know what they are doing first and foremost, and secondly, have an honest, real world dyno. My old TDI left another tuner with 171bhp and went to Darkside's and pulled 155. I would rather have a solid, safe 195bhp than a dyno-happy and smokey 215-220bhp.
Am I happy with the driving experience, the smoothness, the lack of smoke and the kick up the back when I put my foot down? Yes, absolutely!
It was explained to me that these cars which claim to have up to 220bhp (which are all usually very smokey) can sometimes have sky-high EGT's which are over 1000 degrees C from 3500rpm upwards (they flatline at 1000 which is the maximum sensor reading, so are of course going to climb over that figure!)
My EGT's are limited to 850, and I noticed absolutely no smoke on the drive back. The guys said if they had raised the EGT limit they could have got into the low 200's but the extra stress on components is not worth it for the small (5-7bhp) gain, which at the wheels you wouldn't really notice anyway.
Despite the fairly disappointing end NUMBERS, the driving aspect of the car is great and yes, I would pay the money again knowing the outcome. Albeit feel that I could have gone straight for the GTB kit to begin with... anyway...
IMG_0627-1 by Fat Bear Photography, on Flickr
IMG_0629-2 by Fat Bear Photography, on Flickr
Big thanks to Darkside :-) as finally I no longer feel like my car is dogsh*te slow!!!
« Last Edit: November 24, 2014, 03:09:33 pm by xjay1337 »
Offline Biano44
  • The CC GT 200
« Reply #71 on: November 23, 2014, 05:25:48 am »
Thanks for the write up Jay......it's just what I've being waiting for!
Is there any reason you went all the way to Darkside?
As I know Alex can supply and fit the Darkside DP/EGR DELETE.
Offline th3_f15t
  • -Receive: 183
« Reply #72 on: November 23, 2014, 09:41:30 am »
Nice work, good to see some diesel tuning for a change. :happy2:
Offline doylebros
  • -Receive: 310
« Reply #73 on: November 23, 2014, 11:34:51 am »
An educational honest write up there and quite an enjoyable read!
Offline xjay1337
  • -Receive: 377
« Reply #74 on: December 01, 2014, 04:29:15 pm »
I love VAG - what can I say? I have another car FFS.
My new A3...TFSI...quattro....  :wink:
I wanted the Darkside mapping that was all and Alex couldn't have gotten me any discount on those parts.
It will bear divedends when I come to buy the GTB kit which is on the cards...as it gives me a bit more buying power with DsD in the future.
Thanks buddy
There will be more to come haha
Unfortunately doing the miles I do it isn't practical for me to run a petrol and TBH I like having a quick diesel.
No point being coy about it. And i like to be honest about my write ups! glad you enjoyed it.  :star:
