Author Topic: Worried about mechatronic unit going  (Read 14421 times)
Offline P3T3R
  • 05 GTI, R-Tech stage 1
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,82245.0.html
Re: Worried about mechatronic unit going
« Reply #15 on: September 04, 2014, 11:34:16 pm »
My wife asked me to buy a small automatic car as she refuses to drive a manual. :evilgrin:
Luckily I found out her licence is not valid so I'm planning on going to stage 2 before she gets a new one.
I hated automatics in the past but the DSG is awesome. Shes getting on a bit now 05. She does clunk a little bit going from P to R and R to D hopefully that is normal.
I get the odd clunk as well, sounds like its coming from the passengers side. Not sure what it is though.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #16 on: September 04, 2014, 11:54:06 pm »
I made a fast left-right one time and the gf's head made that noise when she cracked it off the window.  :grin:
'07 Red manual
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #17 on: September 05, 2014, 06:49:10 am »
I doubt that will be DSG.
Could even be the turbo, I've heard it can do that if the turbo is f*cked.
The turbo?? You haven't read that on this forum, have you?
I'd suggest PCV is to blame if the idle is very bad. Little stutters at idle are common on these now
Offline bestygti
Re:
« Reply #18 on: September 05, 2014, 09:02:36 am »
Just had my mech unit replaced at vw for a total of 1600 all in, including oil etc. Bought my car not knowing the fault but it became apparent something was wrong when the car was hot. Jerking from a standstill and at low rpm, clunking gears and nearly stalling. I got 50% off goodwill from vw was the car is FWVSH so make that a definite when you come to buy as they won't even entertain any goodwill unless it's got that. Fault is completely sorted now and it's smooth as butter :)
Offline vwrascal
« Reply #19 on: September 05, 2014, 10:39:26 am »
£750? That's cheap in comparison to what I've read?
£750 was the price after the 50% goodwill was taken off  :innocent:
Offline lambera
  • Edition 30 No 1197
Re:
« Reply #20 on: September 05, 2014, 11:22:00 am »
There is a place in Manchester who repair the mechatronic unit alot less costly than vw aswell
Tornado Red Edition 30 No 1197
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Offline bestygti
Re: Re: Re: Worried about mechatronic unit going
« Reply #22 on: September 05, 2014, 11:38:22 am »
Seems 50% goodwill is pretty standard as that's what I got too
Offline SL4VE
« Reply #23 on: September 05, 2014, 01:23:05 pm »
ECU Testing did my multitronic unit for my audi and cost me £500 all in including oil and all the work from a specialist and it was absolutely faultless
Offline AndyBrown
« Reply #24 on: September 05, 2014, 01:42:14 pm »
Where are the based?
Just took mine back to the garage, they've reset the dsg which hasn't sorted the problem, they now recommend changing the oil and after that if it's not fixed they think it could be the clutch packs. What symptoms would I be experiencing if it was the clutch packs. Everything thsts happening is the same as what other people have had with the mechatronic unit being the cause.
The garage is adamant it's not the mechatroinc. Sick of it now as the garage i got it from is 1.5 hour drive from where I live.
*EDIT* Just had a search online and I'll probably looking at £150ish to do an oil change on the dsg!  :confused:
« Last Edit: September 05, 2014, 01:56:00 pm by AndyBrown »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #25 on: September 05, 2014, 03:35:58 pm »
I did mine myself i'm sure the DSG fluid and filter alone cost me a little less than that. :confused:
05 | Tornado Red | DSG
Offline AndyBrown
« Reply #26 on: September 05, 2014, 03:42:50 pm »
I spoke to a local gearbox specialist and he's recommended that I get it booked in with VW as there diagnostics are better than vcds and will be able to diagnose if there is a problem with DSG. Does this sound right?
downsideup
« Reply #27 on: September 15, 2014, 01:36:56 pm »
I spoke to a local VW specialist about mine and from what I told him over the phone he was also adamant that mine probably only needed a new clutch pack and was not the mechatronic. His reason was that it only lurched in 2nd gear at low revs.
He said it was approx £1000 for a new clutch pack from TPS and 3 hrs labour.
I dont have that kind of cash atm so will leave it for now as it is not too bad but will be interested in seeing what VW say if they look at yours!
Offline AndyBrown
« Reply #28 on: September 15, 2014, 01:40:04 pm »
Booked for Wednesday morning so I'll let keep you updated  :happy2:
Offline AndyBrown
« Reply #29 on: September 17, 2014, 12:59:50 pm »
VW confirmed my suspicions this morning, it was the mechatronic, they also quoted me £2287.46 to replace it.
Gunnar fire an email over now to the garage I got it from.
