Author Topic: Urgent Help wanted, no aircon window wipers or EGR flapper thing fault.  (Read 6132 times)
Offline dandav1985
  • -Given: 17
    • http://www.mk5golfgti.co.uk/forum/index.php/topic,72356.0.html
Re: Urgent Help wanted, no aircon window wipers or EGR flapper thing fault.
« Reply #15 on: September 09, 2014, 08:03:31 am »
Hello Mate,
 They would be the fuse for the starter motor and that with a 8mm bolt holding them into position? Ive checked these with a multi meter all seem OK ill get some electrical cleaner today and a small wire brush and see if I can clean up better.
Cheers Dan
Sprint Blue Audi S3, 8P3 s-tronic, Panoramic Roof.
Stage 2 shark remap, Turbo back Miltek, CTS Turbo intake.....322bhp.
Auto lights, Auto wipers, Dimming-Anti Dazzle folding mirrors, Electric & heated seats, Bi-Xenons, Hill Assist, TPMS, Parking Ad, TV Head rest, RNS-E etc..................
Genuine VCDS (vag com) owner
Offline doylebros
  • -Receive: 310
« Reply #16 on: September 09, 2014, 08:06:37 am »
Check all the high amp fuses in that fuse box 50A is the feed for the fans.
Offline dandav1985
  • -Given: 17
« Reply #17 on: September 09, 2014, 05:24:33 pm »
Hello,
 All fuses checked and all cleaned up, ASV seems to be working, no engine light or fault codes on VCDS. Still no air con or condensor fans. Would this be coninsidance that the AC needs regased.
Cheers Dan
Offline doylebros
  • -Receive: 310
« Reply #18 on: September 09, 2014, 09:15:13 pm »
Use VCDS to run the fans in output test for that module.
Offline dandav1985
  • -Given: 17
« Reply #19 on: September 15, 2014, 08:19:29 pm »
Hello,
 Output test was done via VCDS and the fans worked perfectly and all seems good, thought we would try degassing and still not working at all, recovered about 320g of r134a and could only get 440g back in for some reason but the system should hold around 520g ish.
Compressor pulley seems to be turning ok, could it be the pressure switch on the compressor suction/discharge side?
Any more help would be great.
Cheers Dan
Offline doylebros
  • -Receive: 310
« Reply #20 on: September 15, 2014, 08:41:58 pm »
The same output testes could be used to show the compressor draw current which would confirm it's operation.
Common failure item on that side of things:-
http://www.myturbodiesel.com/threads/ac-not-working-in-fla.11391/
The switch is a very common failure item but would normally (but not always) show as fault when scanned.
If you fit a new switch fit a new seal its best practice!
However, the best advice I received was to re-gas and make sure the leak detecting dye is added which will allow fault finding of the system components!
Offline skard
  • -Receive: 245
« Reply #21 on: September 16, 2014, 03:57:15 pm »
The compressor pulley turning is not an indication of it 'working' as it does not have the standard type clutch mechanism. It turns all the time even when off on these cars.
Look down at the pulley, if there is a centre bolt protruding then the engagement plate is probably gubbed. Search for 'delphi fix' and it should have a post by me showing what I mean, the splines wear off on the engagement shaft.
