Author Topic: Dsg quick launch question  (Read 2573 times)
Offline bigtop
« on: September 26, 2014, 10:03:57 pm »
How do you dsg guys get a quick launch, say at a busy roundabout and need to pull out quick
There seems to be a little bit of power for a second then boom it goes like the clappers
How do i get a quick pull off without the tiny bit of delay?
Do i need to use launch control every time? Or can i rev it a bit in neutral and then put it into gear?
Or do i just need to push the accelerator down further? Is there a certain amount it has to be pushed, and thers an instant response?
Its only now and then id ever need it but just be nice to know what the quickest launch is
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Dsg quick launch question
« Reply #1 on: September 26, 2014, 10:24:58 pm »
I find if i've been driving miss daisy for a while the dsg gets it wrong next time i try and floor it. So when the kids are not in the car i usually drive in manual mode.
If your in any other gear and need to go quick put the pedal to the floor and this will put you into the lowest available gear.
05 | Tornado Red | DSG
Offline Biano44
  • The CC GT 200
« Reply #2 on: September 27, 2014, 04:49:20 am »
I know exactly what you mean! I'm pretty sure it has something to do with torque limiting in 1st gear.......if I'm right I think a DSG remap would help!
Offline bigtop
« Reply #3 on: September 27, 2014, 07:55:33 am »
Yeah its had a dsg map of some sort
Need to find out what its had done really, might contact the revo place
What about a few revs in neutral then into D?
Quicker start or broken car?
Offline strongbow
« Reply #4 on: September 27, 2014, 08:30:35 am »
I get the same thing happen when slowing for speed humps then picking up again in 2nd. thing it takes time for the one of the dual clutches to engage,good old technology.
Offline bigtop
« Reply #5 on: September 27, 2014, 11:40:22 am »
Would a reset help?
Iv heard you can do a dsg reset with the ignition and brake, has anyone tried it?
Would it be ok to do it with a dsg map?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #6 on: September 27, 2014, 11:51:16 am »
If you foot is fully planted on the brake there will be a delay for the clutch to engage. Get her creeping and gently hold brake in theory clutch should be engaged ready for action.
Offline grumpy
« Reply #7 on: September 27, 2014, 02:53:56 pm »
bigtop, I think it would be a good start to find out what has been done to your gearbox prior to you owning the car. For a sharpish take-off, just engage s mode.
strongbow, if you find your gear selection a little indecisive while negotiating speed bumps, you can always select manual mode and choose the correct gear for your speed.
Cheers...
Offline bigtop
« Reply #8 on: September 27, 2014, 03:07:28 pm »
I have receipts and paperwork for stage two revo, a dsg map, and a reflash back to stage one
Im guessing if its reflashed back to stage one the dsg map will still be there?
I could do with finding the guy who had it before me and see whats what
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #9 on: September 27, 2014, 05:57:58 pm »
Ensure ESP is off!!
It thinks it knows better than me on traction, but it really doesn't...
Edition 30 - no. 1387
Offline strongbow
« Reply #10 on: September 28, 2014, 09:38:17 am »
cheers grump will do. just getting used to the dsg,alot different than the invecs box on my old fto.
Offline simey
    • Sismotorsport
« Reply #11 on: September 28, 2014, 11:37:32 pm »
When you get the start right!!!
