Author Topic: Dazza's Maintenance Thread  (Read 189092 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Dazza's Maintenance Thread
« Reply #90 on: January 27, 2015, 10:05:13 am »
Made a bit more progress on the boot build today. Wish i had bought some smaller amps.
The hinge works needs some beefing up here and there. Need to decide how to get the sub box into the spare wheel well.
Is there going to be air flow to cool the amps?
Yes mate a thermostat switch and a couple of pc fans. Maybe even some LED's :ashamed:
05 | Tornado Red | DSG
Offline xjay1337
  • -Receive: 377
« Reply #91 on: January 28, 2015, 09:53:43 am »
You can fit them, doorcar will bend out slightly but will be OK.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #92 on: January 28, 2015, 10:05:56 am »
They are fitted but the plastic caps that go behind the mids popped off.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #93 on: January 29, 2015, 01:42:45 pm »
On hold at the moment as i'm waiting on some fibreglass to utilise the space in the spare wheel so i can fit the sub.
Did manage to deaden the boot though.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #94 on: January 29, 2015, 01:50:18 pm »
Good job! :happy2:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #95 on: February 04, 2015, 01:13:06 pm »
Thought i would be getting some fibreglass down today but its fooking cold. Have prepped everything ready.
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #96 on: February 04, 2015, 02:59:02 pm »
It will get colder tomorrow according to the weather forecast. :scared:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #97 on: February 04, 2015, 06:19:38 pm »
Started switching out the speakers in the drivers door. Luckily i did not have to take the outer skin off to get the cap behind the mid back on.
Things would have been much easier if i didn't solder the speaker wires.
As the mid is much smaller i will have to make more adaptors.  :sad1:
Offline jedi-knight83
  • -Receive: 41
« Reply #98 on: February 04, 2015, 07:41:59 pm »
Ah you got them. They will fit much better and should sound even better for you.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #99 on: February 04, 2015, 08:25:55 pm »
Yes mate did not realise they will be that small. I wonder if they have as much mid bass as the ones i took out.
Did you make adaptors to fit them?
  • -Receive: 41
« Reply #100 on: February 05, 2015, 08:55:11 am »
Just mdf adapters.
They def aren't bassy but then I doubt this mids you had were either. The bass will all be coming from the 165 woofer and these little ones are for vocals.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #101 on: February 05, 2015, 06:07:33 pm »
Got two layers of fibreglass down. Wasted a lot of resin did not expect it to cure so quickly.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #102 on: February 09, 2015, 05:23:09 pm »
Very slow progress on the sub box.
Do not touch fibreglass if you have OCD. Come to think of just don't do anything if you have OCD.
Started to trim the glass down. Wish i had taped up the base as it's a fooking mess.
Must resist starting over.  :stupid:
Started to cut the lid for the back section of the box.
Manage to get some polyurethane glue to stick that sh*t down.
« Last Edit: February 09, 2015, 05:30:05 pm by dazza »
  • -Receive: 41
« Reply #103 on: February 09, 2015, 05:34:00 pm »
looks like a hell of a lot of work
did you get your new HSK's in yet.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #104 on: February 09, 2015, 05:41:55 pm »
Yep i'd better finish soon the neighbours are not to impressed with all the sawing, grinding, sanding and dust.
Got the HSK's in one side. They do sound better than the ESK's. The ESK's sound harsh at mid to high volume.
Still got a sh*t load to do.
