Author Topic: How to install Oem xenon headlights? CECM wire  (Read 4939 times)
Offline K9
  • VW LifeStyle
« on: November 21, 2014, 09:30:36 pm »
how do you guys do the kufatec extra wire to the CECM so you get bi-xenons? with shutter. seen a pic or pics of when installing the automatic range finder etc. but want ot know how hard is simply it is to drag the wire to your CECM. pics would help  :happy2:
« Last Edit: November 21, 2014, 09:36:54 pm by K9 »
Offline doylebros
  • -Receive: 310
Offline K9
  • VW LifeStyle
Re: How to install Oem xenon headlights? CECM wire
« Reply #2 on: November 22, 2014, 01:14:28 pm »
This might help you
http://forums.mwerks.com/showthread.php?3552517-Golf-V-GTI-OEM-Xenon-Installation-Completed
seen that some times but cant figure out what cabel only comes from the kufatec xenon adapter, confused  :sad1:
Offline K9
  • VW LifeStyle
« Reply #3 on: November 23, 2014, 11:45:39 am »
pump
Offline doylebros
  • -Receive: 310
« Reply #4 on: November 23, 2014, 11:56:20 am »
This is from that original link
Quote, originally posted by DimiK »
Then i connect pin 11 from one headlight to connector A pin 5 (should be empty so just plug it in) and then from the other headlight pin 11 to connector D of the CECM pin number 6 (this also is empty).
What bit is confusing you?
Offline K9
  • VW LifeStyle
« Reply #5 on: November 23, 2014, 02:29:02 pm »
do i need to make any new wires or are they all inc with the kufatec one? and is there only one wire going from headlights to CECM?
Offline STV4R
« Reply #6 on: November 23, 2014, 03:13:39 pm »
Everything is included with the adapters just plug'n'play.
There is only 1 wire from each adapter that connects to the CECM but you might want to tell Kufatec when ordering that you need it. Because mine never had the extra wires so had to send them back for them to add it for me.  :happy2:
Offline K9
  • VW LifeStyle
« Reply #7 on: November 23, 2014, 07:37:29 pm »
this is the one that i ordered http://www.ebay.com/itm/400289281147?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT looks like the wire is added and it says in the descb. that it with the extra wire to cecm. is it easy to drag the cabel to cecm?
