Author Topic: Does iron X remove wax protection from wheels?  (Read 3823 times)
Offline paulw123
  • -Receive: 47
« on: December 17, 2014, 01:10:58 pm »
As title, do I have to re-apply protective wax every time after using iron X or similar?
or is there a wheel sealant that it won't take off?
Re: Does iron X remove wax protection from wheels?
« Reply #1 on: December 17, 2014, 01:16:40 pm »
Yes. Anything stronger than mild soap/shampoo will strip wax. How often are you using iron X?
Offline paulw123
  • -Receive: 47
« Reply #2 on: December 17, 2014, 01:30:07 pm »
well not that often, as I guessed it might take all protection off, and I didn't want to spend ages waxing them again, I find it sooooo boring a task.
is every 3months about right?
« Reply #3 on: December 17, 2014, 02:53:06 pm »
It's up to you how frequently you do your wheels. At change over times, when the winter alloys go on/off, the wheels get a thorough cleaning. Otherwise a few times a year they get washed/tardis/ironx/LSP. Shouldn't need to touch them during regular washes.
 Sealant or wax won't stop brake dust but does make it easier to clean the wheels on your weekly wash.
Offline xjay1337
  • -Receive: 377
« Reply #4 on: December 17, 2014, 03:14:46 pm »
Well, it depends on what sort of coating you have.
If it's just an organic wax then while still being PH neutral the Iron X can possibly degrade the wax. It won't "remove" it though.
If you have something like cquartz/dlux/qtechniq then it will be more resistant but with these coatings you generally only need a good scrub with a mitt or some brushes and regular shampoo.
If you have waxed your wheels then a weak mix of ph neutral wheel cleaner is usually enough especially if you at least jet your wheels off once a week.
i try and wash my car every week at least and my wheels were all FK1000p'd and they stopped beading after about a month. I hydro 2 them when I can get a chance.
