October 17, 2026, 11:49:41 pm
All Things Mk5
Mk5 General Area
Interior or dome light issue
Topic: Interior or dome light issue (Read 1704 times)
Stevepd
Always Involved
-Given: 49
-Receive: 4
December 19, 2014, 08:20:28 am »
Mine hasn't worked since I bought the car. Yesterday I had the time so had a look at others post on how too. Removing the panels to reveal the rocker switch which I took out and gave it a clean. The info said to bend the legs apart a bit as they can go together, so did that and refitted which instantly blew the fuse. I've removed the rocker switch again and replaced the blown 7.5amp fuse. Can anybody offer any further advice on how to set this up.
The light do work if you push the rocker switch quite hard but release your finger and they go off. Everything else works as advertised.
Standard 5 Door Shadow blue.
callis
Always Involved
-Given: 1
-Receive: 10
Re: Interior or dome light issue
Reply #1 on:
December 23, 2014, 10:52:49 am »
Hi
Guys i have the same kinda issue with my rocker switch. However my legs have lost their spring.
So can anyone give me the part number and price so i can get a new one ordered. The VW garage is a distance from me and they are not very good on the phone.
so its the interior rocket switch.
cheers
05 GTI 5 Door, sunroof, met paint, 18" monza, Leather Anthacite, front centre armrest, xenon headlights, Lux pack 2, Sensors, Winter Pack.
doylebros
Just look at my post count
-Given: 44
-Receive: 310
Reply #2 on:
December 23, 2014, 01:02:34 pm »
Seems the switch only comes with the light?
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=9&grf=094700420&bf=94705&hgug=947&ug=47&parent_id=2363557
The part is chassis number dependant for the whole assembly.
Last Edit: December 23, 2014, 01:05:14 pm by doylebros
callis
Always Involved
-Given: 1
-Receive: 10
Reply #3 on:
December 23, 2014, 03:00:52 pm »
hmmm, now thats a bummer. Guess i will have a play and see if i can fix it myself.
andybon
Won't Shut up.
-Given: 11
-Receive: 8
Reply #4 on:
May 05, 2015, 05:38:01 pm »
Mine has just done the same, stopped working so had a look and it looked really grimy inside, cleaned it and when it came to putting it back together there was no tension on the switch, now the fuse has popped!
How hard can it be?
All Things Mk5
Mk5 General Area
