Author Topic: P0441 EVAP emission control sys: incorrect flow. Need part numbers please.  (Read 4544 times)
Offline UTSI
Can anyone provide me the latest part numbers for the related issue?
 P0441 - EVAP emission control sys: incorrect flow.
I need the part numbers for these following parts please.
solenoid n80
Check valve
Charcoal canister
I need to purchase these to eliminate the annoying p0441 code.
Offline xjay1337
  • -Receive: 377
Clear the code and it will go away
Had this intermittently for ages with mine.
Never bothered to fix it.
Offline howie1987
  • -Given: 92
  • -Receive: 21
I had this for ages.  And kepted coming back every few week so Changed the n80 valve and that fixed it.
Offline UTSI
I already cleared the fault it can back again the day after
Offline UTSI
Does this fault cause any power lose? It seems that i may have felt power lose at the high rpm, but maybe that me overthinking?
Offline xjay1337
  • -Receive: 377
Ah really? Sometimes I would have it on again quite soon, within a couple of days, sometimes it didn't come back for a whole month or even more! Haha
I don't think it effects running of the engine.
homesqueeze
I had the 001089 fault code keep coming back all the time. Had a new evap valve (06E906517A) fitted which is usually supposed to cure it, but it didn't work. So I got the charcoal canister (1K0201801E) replaced and so far that seems to have solved the problem. I did need a new piece of pipework (1K02021160BG) for the canister as the latest version has been revised.
Offline UTSI
Funny enough mine only came out the factory just a year ago, currently at 15k miles and stock tune and this issue has arrived ever so quickly. I am sure this engine has all the revised 2.0 tfsi parts and it seems they also break down as well :surprised:
« Last Edit: January 21, 2015, 09:26:39 pm by UTSI »
