Author Topic: Revo map help  (Read 5639 times)
Offline DomBacon
Revo map help
« on: February 07, 2015, 02:07:39 pm »
Currently running stage 2 on my ed30
Had to unconnect the battery so my map settings went back to 0.0.0
Mods constist of
Full exhaust
Forge twintake system
forge twintercooler
Forge dv
Running on vpower
Anyone know what the settings should be?
Cheers Dom.
Offline GTiBlues
  • Mr Blues
    • Bookface
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
Re: Revo map help
« Reply #1 on: February 07, 2015, 02:15:11 pm »
Take it to your local Revo dealer, it'll cost you their time to put the settings back in. I only had to pay a tenner for a tweak on mine
Re: Revo map help
« Reply #2 on: February 07, 2015, 02:18:47 pm »
Depends. Which version of the map do you have? They changed the boost profiles a year or so ago.
Offline DomBacon
Re: Revo map help
« Reply #3 on: February 07, 2015, 02:53:11 pm »
I would take it to my local dealer but one of them completely screwed up the settings and then went AMD to get it sorted but they can't do anything till late next week :/
Offline TaylorGTi
Re: Revo map help
« Reply #4 on: February 07, 2015, 06:27:44 pm »
Does disconnecting the baterry wipe a remap?!
R-tech Stage 2+ Pirelli Gti
Offline Flaffy
Re: Revo map help
« Reply #5 on: February 07, 2015, 06:42:16 pm »
Yup, I've got Revo stage 1, and it happened to me twice.. Im in the market for a 2nd hand SPS box  :grin:
Anders
Best Regards
Anders T
Mk5 Gti DSG 2005
Offline Dubbin
Re: Revo map help
« Reply #6 on: February 07, 2015, 10:01:39 pm »
Anders
It will only wipe the Revo map settings. Other maps are not effected by battery disconnects.
GTI, DSG, Xenons, Laser Blue, Sunroof, 5 Door, Monza IIs, MFSW
Offline DomBacon
Re: Revo map help
« Reply #7 on: February 08, 2015, 12:05:54 am »
It just wipes the settings back to 0.0.0
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
Re: Revo map help
« Reply #8 on: February 08, 2015, 11:25:14 am »
This happened to a forum member at Surrey a Rolling road yesterday. Luckily someone had an SPS switch to put the settings back
Re: Revo map help
« Reply #9 on: February 08, 2015, 12:57:10 pm »
Think a company like revo wouldn't design a map that loses the settings due to a flat battery
Offline DomBacon
Re: Revo map help
« Reply #10 on: February 08, 2015, 11:47:03 pm »
You would of thought so but guess not
I was looking into a revo sps switch but I was a bit confused because you have 3 settings. Boost, timing and fuel, on the switch it just has numbers on it, or is it like preset buttons?
Offline floydsolo
Re: Revo map help
« Reply #11 on: February 09, 2015, 12:12:03 am »
Yes you defo need the SPS switch as it resets itself to factory when battery is disconnected. On the switch, No 1 is factory, 2 is Revo map, 3 is for running on 95 fuel & 4 is the valet mode.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Revo map help
« Reply #12 on: February 09, 2015, 08:42:31 am »
1,0,0   0,0,0 is Valet mode
It not an issue with Revo as such, it's the way the ECU works. The same happens if you go to R-Tech with the 5 switchable map option - It will revert to the original/basic map and you would have to switch it again. Difference with Revo is that there is no inbuilt switching option like APR with the CC stalk, or Rtech with the brake/clutch pedal combo.... Revo uses a hardware switch
Not true at all, 1 is Factory, but presets 2, 3, and 4 are user definable. See here: http://www.revotechnik.com/product-details//serial-port-switch-sps
Offline mvb12
  • -Receive: 64
Re: Revo map help
« Reply #13 on: February 09, 2015, 08:50:01 am »
AMD are not REVO dealers so no sure why they would help  :confused:
I wouldn't let AMD change a light bulb.
If your in London and you can call your tuner that set you up with the settings a can put them back on for you  :happy2:
Offline DomBacon
Re: Revo map help
« Reply #14 on: February 09, 2015, 09:58:46 am »
AMD isn't a revo tuner anymore but they still have the software to sort the settings out for people.
