Author Topic: RNS510, mfsw and highline coding issues.......  (Read 4205 times)
Offline mk4gti-t
  • -Given: 61
« on: March 20, 2015, 05:17:31 am »
I've recently fitted an RNS510 but can't get the track up and down buttons working correctly  :confused:
When I change the code in the navigation module to get them to work it stops the mfd displaying the compass direction in the top left hand corner of the screen.
Also I can't scroll through audio, set up, navigation menus etc even with the stalk buttons?
Any ideas as to what the coding should be?
My car is a 2005 gti dsg and I've fitted highline dash, old style mfsw with paddles and RNS510. I've also swapped the steering wheel controler to the 'ch' type.
Strangely though when I had a newer type mfsw without paddles all worked fine???
Offline skard
  • -Receive: 245
Re: RNS510, mfsw and highline coding issues.......
« Reply #1 on: March 20, 2015, 07:30:55 am »
Unticked BAP in the coding for stereo?
Offline mk4gti-t
  • -Given: 61
« Reply #2 on: March 20, 2015, 07:38:14 am »
Yea the compass comes back but the track up/down buttons stop working then.....
Offline skard
  • -Receive: 245
« Reply #3 on: March 20, 2015, 07:43:11 am »
Did you have a GPS compass module before the RNS510?
Offline mk4gti-t
  • -Given: 61
« Reply #4 on: March 20, 2015, 11:42:22 am »
I used to have an mfd2 and got the gps antenna off eBay. It all worked fine then.
Offline skard
  • -Receive: 245
« Reply #5 on: March 20, 2015, 02:45:42 pm »
The GPS compass module is seperate to the stereo. Probably rare for a mk5 to have it but if you do, it can interfere with the RNS510 until you deactivate/unplug it.
Post up a scan.
You probably have a later cluster that is intended for use with the newer MFSW buttons.
Offline mk4gti-t
  • -Given: 61
« Reply #6 on: March 20, 2015, 03:08:57 pm »
No can't find a compass module installed anywhere. My cluster part number is 1K6 920 972 D not sure how old or new that is though?
Offline skard
  • -Receive: 245
« Reply #7 on: March 20, 2015, 03:45:05 pm »
That cluster is the new button generation but should work ok.
Have you got a scan to post up?
Offline mk4gti-t
  • -Given: 61
« Reply #8 on: March 20, 2015, 03:57:48 pm »
No sorry need to get it to my mates to get a scan. What should I be looking for to post on here? Thanks for the help by the way  :happy2:
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #9 on: March 20, 2015, 08:05:35 pm »
My buttons didnt work properly until i changed wiper stalk for the one without buttons.
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline mk4gti-t
  • -Given: 61
« Reply #10 on: March 20, 2015, 08:08:08 pm »
How did you get to the menus on the display then? I have no menu button on the old style steering wheel.....
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #11 on: March 22, 2015, 09:34:22 pm »
Well.. I have mk6 steering wheel mate
Offline mk4gti-t
  • -Given: 61
« Reply #12 on: March 22, 2015, 10:28:44 pm »
Oh I see......
