Author Topic: How do i remove rear controll arm?  (Read 7860 times)
Offline K9
  • VW LifeStyle
« on: March 30, 2015, 04:49:08 pm »
i need to change the inner bushings on both sides as one side is cracked :(
tried google but can't really find anything.
ideas and suggestions please  :happy2:
Offline GTI-Pirelli
  • -Receive: 27
Re: How do i remove rear controll arm?
« Reply #1 on: March 30, 2015, 05:28:09 pm »
Cut it off.
I did mine a few weeks ago. Unfortunately, the bolts tend to seize into the inner collar of the bushes.
- Jack the car up (I put axle stands under both sides of the rear of the sub-frame where it bolts to the body)
- May need to remove the rear of the exhaust for better access
- Jack up the outside edge of the control arm (to take the tension of the spring)
- Remove the bolt attached the bottom of the hub assembly
- Lower the jack and remove the spring
- Remove the inner eccentric bolt (if it comes out, you are extremely lucky)
     - If it doesn't come out, then you have to cut the arm out of the sub-frame
     - I used a 230mm grinder - be extremely careful not to cut the sub-frame!
The bushes are part of the arm assembly as supplied by VW. Approx £75 each (both the same L & R)
Bolts + Nuts + washers were under £20 iirc.
2017 Audi S4
Offline K9
  • VW LifeStyle
« Reply #2 on: March 30, 2015, 05:33:08 pm »
Cut it off.
a auto part store here in Finland do sell the bushes for the arms without needing to buy the arm new.
so it's just like when i changed from stock to coilovers at the rear when removed the spring and damper? + i need to un-bolt the inner bolt to get the arm out?
@GTI-Pirelli
Offline GTI-Pirelli
  • -Receive: 27
« Reply #3 on: March 30, 2015, 06:10:33 pm »
@GTI-Pirelli
The bush is mounted in the control arm. The bolt goes through the sub-frame, then through the bush.
If you can remove the bolt, then you should be able to get the bush out and replace it.
I saw the bushes on their own, but couldn't remove the bolts so chose to cut through the arm.
I needed my car so couldn't attempt to remove it and assess what I needed afterwards. I just went ahead and bought the new control arms.
You might be able to remove the bolts with heat. I think one of my bolts came out after I'd cut half way through it.
It is right behind the fuel tank though.
2017 Audi S4
Offline K9
  • VW LifeStyle
« Reply #4 on: March 30, 2015, 06:17:44 pm »
just to confirm that it's just like when removing rear damper and spring?
