September 12, 2026, 03:45:32 am
All Things Mk5
Mk5 General Area
Drop in MPG
Topic: Drop in MPG (Read 2359 times)
samiul11
Always Involved
-Given: 9
-Receive: 15
Drop in MPG
March 31, 2015, 04:35:13 pm »
Hi guys i mainly do city driving and i get around 23mpg with mixed driving however recently it has dropped to 17 mpg and the computer takes away 5 miles every mile or so
is this to do with the pcv and would a pcv revamp fix the issues? Thanks any help is appreciated
AndyBrown
Won't Shut up.
-Given: 23
-Receive: 17
Re: Drop in MPG
Reply #1 on:
March 31, 2015, 04:39:41 pm »
Could be a sticking caliper?
samiul11
Always Involved
-Given: 9
-Receive: 15
Re: Drop in MPG
Reply #2 on:
March 31, 2015, 05:24:07 pm »
Quote from: AndyBrown on March 31, 2015, 04:39:41 pm
How would i know if i have a seized caliper? Only thing i can think of is check each wheel and see if any of them are really hot?
KieranED30
Always Involved
-Given: 1
-Receive: 12
Burning Rubber Since 16th Febuary 2012
My Ride:
Re: Drop in MPG
Reply #3 on:
March 31, 2015, 05:37:10 pm »
^^^ that, excessive brake dust and squeezing when setting off
longbelly
Just Arrived
-Given: 5
-Receive: 0
Re: Drop in MPG
Reply #4 on:
March 31, 2015, 09:01:27 pm »
We had a sticking caliper on our focus, sounds similar to a wheel bearing drone and got very hot
samiul11
Always Involved
-Given: 9
-Receive: 15
Re: Drop in MPG
Reply #5 on:
April 01, 2015, 06:20:05 pm »
Hmm went for a drive today and my brakes seem fine and cant feel any heat coming from them
any other ideas?
GrayMK5GTI
Global Moderator
Just look at my post count
-Given: 125
-Receive: 249
Re: Drop in MPG
Reply #6 on:
April 02, 2015, 11:55:00 am »
Dont get a PCV revamp, just replace with the latest OEM PCV (if that is whats causing your problem)
OSB
Always Involved
-Given: 32
-Receive: 17
Re: Drop in MPG
Reply #7 on:
April 03, 2015, 01:40:49 pm »
As above. Check/change PCV with OEM
Check / replace air filter
Check / replace spark plugs.
These are relatively cheap and easy to do.
Then, if that lot doesn't work - get a VCDS scan and se if it throws up any faults.
Good luck!
samiul11
Always Involved
-Given: 9
-Receive: 15
Re: Drop in MPG
Reply #8 on:
April 03, 2015, 01:48:19 pm »
Thanks guys!
All Things Mk5
Mk5 General Area
Drop in MPG
